Old 17-03-2005, 11:18 AM   #1 (permalink)
ashfahan's Avatar
Default HELP PLZZZZ!!!
plzz help!!!
whenever i try to run any setup file(old) it gives error.
c:\windows\system32\autoexec.nt.
this system file is not suitable for running msdos and windows application.
plzz help.
i use win xp
p4,intel 865 gbf,512 ddr,geforce fx 5200 128 mb
ashfahan_alam@yahoo.com
ashfahan is offline
Old 17-03-2005, 01:38 PM   #2 (permalink)
can u give more details abt current os , previous os etc and config and the history of the problem. pls be descriptive coz troubleshooting needs a better description than this
h4xbox is offline
Old 17-03-2005, 05:51 PM   #3 (permalink)
i let it go cuz i thot someone with enuff brains would ask him to search and give him links
unfortunately it was u who replied !
@ashfahan is it a 16 bit windows subsystem error ?
follow bat's advice here
http://www.thinkdigit.com/forum/view...ht=autoexec+nt
No Mercy, No Limits.
theraven is offline
Old 18-03-2005, 12:21 AM   #4 (permalink)
hafees's Avatar
AUTOEXEC.NT is used to initialize the MS-DOS environment unless a different startup file is specified in an application's PIF.
There will be some back ups available. so just search for it. and replace with the new one. Probably the useful commands in there are
REM Install CD ROM extensions
lh %SystemRoot%\system32\mscdexnt.exe
REM Install network redirector (load before dosx.exe)
lh %SystemRoot%\system32\redir
REM Install DPMI support
lh %SystemRoot%\system32\dosx
if u couldnt find a backup file just create a file with these entries.
hafees is offline
Old 18-03-2005, 04:17 AM   #5 (permalink)
Default autoexec.nt
This error message started with XP SP2. This is also known as 16 Bit Subsystem" error. To resolve the issue download the XP_FIX.exe from the following link and run it.
http://www.visualtour.com/downloads/xp_fix.exe.
After that just run the software.
note: Make sure you do not restart the computer before installing your desired software.
RajŪ Anyone else is not me...!!!
rajas is offline
- by Piyush
