You cannot use Partition Magic to resize dynamic disks in Windows 2000/XP/2003. However, you can use the Disk Management snap-in (Access it with Start>Run>diskmgmt.msc) and then use it to delete/span dynamic volumes. However, its recommended that you do not use Dynamic Disks in a home PC environment.
Playing FEAR XP/LSW2
