Originally Posted by ComputerUser
Can I run dos games using any other program other than Dosbox? I am tired of mounting each time I want to play,so is there any other program?
You can just dosbox.conf in DOSBox directory and set the autorun variables!
At the full bottom of the file, there will be a section called
[autoexec]
Add the following below it.
mount c c:\path-to-be-mounted\
