Old 09-10-2007, 10:25 AM   #1 (permalink)
evewin89's Avatar
Default Not able to delete setup & some files...
i m Not able to delete some files under C:\windows\system32\Macromed flash.these files are (Flash9d.ocx,FlashUtil9d,genuinst,KB923789,UninstF l)... please help.....
Evil Lives 4ever......
evewin89 is offline
Old 09-10-2007, 05:27 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Not able to delete setup & some files...
try deleting in safe mode .......
... W H O T ...
ax3 is offline
Old 09-10-2007, 07:34 PM   #3 (permalink)
evewin89's Avatar
ok i ll try..... but even if i try 2 delete it from other partition OS,its fails 2 delete the 2 files (FlashUtil9d.exe,Flash9d.ocx)
evewin89 is offline
Old 10-10-2007, 06:32 PM   #4 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
TRy Unlocker
http://ccollomb.free.fr/unlocker/
||uLtiMaTE WinNER||
Ron is offline
Old 10-10-2007, 06:59 PM   #5 (permalink)
Kiran.dks's Avatar
I think you are trying to delete " Protected System files". It's safe not to delete them.
Kiran Kumar R
Kiran.dks is offline
Old 10-10-2007, 09:52 PM   #6 (permalink)
Evil Genius
faraaz's Avatar
Boot from a Live CD which has ntfs write support...it will make everything vanish...
Roses are #FF0000, Violets are #0000FF...All of my base are belong to you!
faraaz is offline
Old 10-10-2007, 10:03 PM   #7 (permalink)
"The Gentleman"
vish786's Avatar
use "moveonboot" and remove any fuking file
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Is it okay to delete files in this folders ThinkFree QnA (read only) 1 24-07-2007 04:03 PM
windows not allowing me to delete files..... Omsck Software Q&A 23 14-05-2007 01:03 PM
Delete files from rapidshare. SE><IE QnA (read only) 2 11-11-2006 08:36 PM
Extract Files from setup mako_123 QnA (read only) 2 26-04-2005 09:26 AM
UT 04 setup files corupted !!! rachitboom2 Gamerz 9 12-04-2005 03:16 PM
- by Piyush
