Well...to use Image by Norton Ghost or any other software...you must have the same hardware in all your 10 pcs......
Best way for you is to slipstream softwares which you want in every pc....and just run the setup....you can use nlite for this purpose...
http://www.nliteos.com/nlite.html
Above link gives you detailed instruction as well as link for downloading the software....
If any problem persist...ask again..........
thanks...
