Old 07-10-2007, 11:42 AM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default athlon vs turion
i m buyin a laptop but i cannot decide sud i go for AMD Athlon X2 or AMD turion X2.
what is de difference???
please help
which is better
ankushkool is offline
Old 07-10-2007, 11:52 AM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: athlon vs turion
go for turion x2, coz its made for mobile usage, it means especially for laptops.
you might not find much performance difference between these two, but turion consumes less power, so less heat too
Gigacore is offline
Old 07-10-2007, 12:06 PM   #3 (permalink)
ankushkool's Avatar
is it de only advantage?
Old 07-10-2007, 12:26 PM   #4 (permalink)
Web developer
narangz's Avatar
There are some Athlons just for laptops. Example- AMD Athlon 64 X2 TK-53. Actually it is a high performance variant of Turion.
You'll get higher battery life than standard Athlons in case of Turions. Less heat means cooler laptop. Cooler laptop means increased machine life.
Performance wise Athlons will perform better.
EDIT-
More info here:
Turions
Athlon X2
narangz is offline
Old 07-10-2007, 12:37 PM   #5 (permalink)
Dreamweaver
Gigacore's Avatar
+1 for the above post.
Gigacore is offline
Old 08-10-2007, 08:13 PM   #6 (permalink)
ankushkool's Avatar
thanks... i think i got my answer
AMD Turion vs. Core2 duo romeo_8693 CPU / Motherboards 9 08-09-2007 11:56 PM
AMD Turion 64 X-2 is better or not..? deepakg Mobiles and Tablets 3 03-06-2007 09:59 AM
Turion x2 or core 2 duo speedyguy Hardware Q&A 6 27-03-2007 04:21 PM
AMD Turion or Centrino?? kumars CPU / Motherboards 15 17-08-2006 10:18 AM
- by Piyush
