Old 06-10-2007, 10:44 AM   #1 (permalink)
digit i am thinking's Avatar
Exclamation Rw Cd Error
I hav burnt two RW CDs with nero 7.When tried to copy into pc they don't says error in copying.surprisingly both RWs has got error at same sector.
I erase it burnt it again but prob remains the same
Then i burn image file to third RW.Nero say burn process completed successfully.but when i open CD it shows nothing.just total size 0 byte & free size 0 byte.
Is this because of nero7.All the RWs were working fine before this prob.
Help me Plz............
digit i am thinking is offline
Old 06-10-2007, 10:48 AM   #2 (permalink)
Nav11aug's Avatar
Default Re: Rw Cd Error
try with a different software, if u r having the same problem then the problem is with the drive.
If not, the problem is with Nero 7, either it isnt compatible with your drive or improper integration with the OS, reinstall.
Btw, which drive are you using. Samsung optical drives suck. Me myself saw 4 drives screw up within 2 years, two of them my own
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 06-10-2007, 11:01 AM   #3 (permalink)
I am using Sony DVD RW
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
error while trying to retrive text for error ORA-12203 vikasg03 Software Q&A 1 14-11-2005 02:48 PM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
- by Piyush
