Old 16-03-2005, 10:40 AM   #1 (permalink)
Default Mysterious DVD?
This is a wierd error that i came across. I have an AMD Sampron processor and a Gigabyte Motherboard with 128Mb DDR ram. I also have a samsung dvd drive installed. I bought this system in november. It was working fine till now. The system works fine normally but if i put a cd or a dvd into the drive my system shuts down immediately. Its not a gradual shutdown, the whole system just goes down. Can someone tell me what the problem could be?.
Thanks in advance
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 16-03-2005, 11:03 AM   #2 (permalink)
Ignorance is BLISS !!
I dunno for sure
B-U-T !!!
Can it be a VIRUS ?
Most probably it is one of the W32 ones that might cause damage when the autorun feature is invoked !
rajkumar_personal is offline
Old 16-03-2005, 11:12 AM   #3 (permalink)
Hmm. Could be. But a priliminary scan revealed nothing. I used NAV 2005.
shyam911 is offline
Old 16-03-2005, 01:59 PM   #4 (permalink)
The same thing happens to me when I am playing small games provided by digit and press <escape> key to pause.
Don\'t assume. It makes an ASS out of U and ME
tushar_novice is offline
Old 16-03-2005, 02:43 PM   #5 (permalink)
just perform all the routine stuff ...
scan with latest virus definitions
if possible do an online scan
run spybot nd adaware
run > msconfig > clear all unwanted entries
remove CD ROM/DVD ROM drives frm device manager,restart the PC,XP will install back the devices nd check....
still not working ??? check out ur SMPS...can be its fault...as soon as CD/DVD drive draws power the system shuts down...try out this way...disable autorun..insert the disc nd restart i.e the system shud start with a disc already in the drive... open my computer after restart nd browse the CD...see if system shuts down ..
grinning_devil is offline
Old 16-03-2005, 02:44 PM   #6 (permalink)
I guess the SMPS is gone...
..maybe there is power surge or something when rom starts to read.....
had this problem once..
Hitesh Gupta
There are only 10 type of people in world...
1 who understand binary..
1 who don't
hitesh_hg is offline
Old 16-03-2005, 04:01 PM   #7 (permalink)
sunnydiv
Posts: n/a
Originally Posted by rajkumar_personal
I dunno for sure
B-U-T !!!
Can it be a VIRUS ?
dude as far as i know, w32 ones simply means
a virus affecting windows
32 bit system
Old 16-03-2005, 07:23 PM   #8 (permalink)
Laptoping
Sourabh's Avatar
we are soon gonna experience w64 viruzzez
Sourabh is offline
Old 16-03-2005, 08:00 PM   #9 (permalink)
32 bit system
That's what mate !
The Autoplay programs are 32 bit exe (in win XP, it resides within the OS)
and hence it might be vulnerable to the attack !
What say ?
Old 17-03-2005, 02:56 AM   #10 (permalink)
parthbarot's Avatar
i thnk not virus....
plz forgive if i m wrong..
may be..............................................
in some cabinets..cd drive/DVD drives nearer to RAM slot...
so when u open & close the drive , it just stucks with the RAM & RAM will jst move or anything with it can turn it in OFF/RESTART...
in my college that was the bad thing that when C inserted .. it stucks with the RAM & " RAM ke hilne se PC restart hota tha"...Bcs small cabinets //or// big C/DVD drive....
so plz check that ur RAM should not stucked by ur drive
regards
www.techlads.com
Paarth.
parthbarot is offline
Old 17-03-2005, 01:24 PM   #11 (permalink)
Just scan with avg. the one stop solution to ur virus problems
h4xbox is offline
- by Piyush
