Old 01-10-2007, 04:42 PM   #1 (permalink)
amanjagga's Avatar
Arrow Techie's help needed
Hi Guys!
I need you help.I have my cousin and he uses my PC .But i do not want that he should use my pc. If i mada a login password i have to tell the password due to our relations. So i need you help
I need any method which can stop him from using my PC provided he should not know about my scheme.
Please help!
www.hhostingg.com
amanjagga is offline
Old 01-10-2007, 05:28 PM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Techie's help needed
the only way to secure pc is my keeping password even though you created bios password you should tell him,so first create another user account to him under his name with limited permissions not an administrator,secondly make the data or folders which you think to be unview by everyone secure, using some folder locks or so many techniques are there for this,see my thread in forums where a technique of folder is visible to everyone but when double clicked nothing will be there inside and folder looks like recycle bin see all those tweaks in internet also
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 01-10-2007, 05:44 PM   #3 (permalink)
amanjagga's Avatar
Thanks but my cousin is very .......................
i want him not to use my PC not even limited permissions.And he will also be sucessful in forcing me if even i create his limited user acc.
www.hhostingg.com
Old 01-10-2007, 05:51 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Well if you are so compromising, don't bother doing anything
Or simply, erase XP and run Linux (Or fart a flamethrower at your SMPS)
QwertyManiac is offline
Old 01-10-2007, 05:58 PM   #5 (permalink)
Deadman Walking
dude how that is possible to not switch on your pc
Learn to live... &
Live to learn...
Old 01-10-2007, 06:15 PM   #6 (permalink)
AJJU
azzu's Avatar
Run linux
I love and Live to Design
azzu is offline
Old 01-10-2007, 06:36 PM   #7 (permalink)
slugger's Avatar
take out d battery from the BIOS everytime u stop using d computer
ur BIOS settings may get changed but u can change them back next time u use ur comp
slugger is offline
Old 01-10-2007, 06:50 PM   #8 (permalink)
The Devil's Advocate
iMav's Avatar
or a simple solution the power button is connected to the mobo disconnect that wire its a simple jumper type plastic peice u can remove it and plug it back in ....
http://beingmanan.com
iMav is offline
Old 01-10-2007, 07:01 PM   #9 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
+! for start using linux.Nothing beats it.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 01-10-2007, 07:29 PM   #10 (permalink)
Commander in Chief
Yeah, nothing beats it, not even your brother
Old 01-10-2007, 07:34 PM   #11 (permalink)
download virus?
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 01-10-2007, 08:06 PM   #12 (permalink)
amanjagga's Avatar
Guys thanks for your suggestions
But still more good powerful reason is required
I do not like touching hime my PC and eats my full brain when he sits on Pc
help me from my..........................
www.hhostingg.com
Old 01-10-2007, 08:15 PM   #13 (permalink)
slap him,fight with him,give him electric shock,try to hypnotise him,tell him he annoys you,ask him to pay you for using your pc,tell him your mobo+processor went kaput and he will have to buy new ones if he want to use your pc.
Still need more suggestions?
Old 01-10-2007, 08:15 PM   #14 (permalink)
I see right through you.
Sykora's Avatar
Let's get this straight :
-- Your cousin wants to use the computer, you don't want him to.
-- If you set a password on anything, you'd have to tell him for the sake of family relations.
-- You don't want to touch the inside of your computer.
-- He's very successful at forcing things out of you.
wtf? Do you want to use the computer or not? If yes, you're going to have to toughen up and learn to keep a few secrets. If no...well then there's no point anyway.
There's no point in using linux any more than there is in using windows in this case if you'll tell him the root password, and even less sense in the matter if neither of you know how to use linux.
What a mess.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 01-10-2007, 08:33 PM   #15 (permalink)
amanjagga's Avatar
Yah ggod reason
It always comes to my dreams
But not able to make my dreams come true.
www.hhostingg.com
Old 01-10-2007, 08:56 PM   #16 (permalink)
Cool G5's Avatar
Transfer pc to some other secret room & tell ur cousin that u sold it.This will keep him away.Isn't useful if he comes to stay at ur home.
Cool G5 is offline
Old 01-10-2007, 11:23 PM   #17 (permalink)
Sykora's Avatar
Sell your PC, and tell your cousin you sold it. It will definitely keep him away, and it's guaranteed to work even if he comes to stay at your home. The drawback is that in the absence of the computer, you may be tasked with occupying him, and from what I gather, you won't want to do that.
-- Sykora --
Sykora is offline
Old 02-10-2007, 09:45 PM   #18 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Just replace ur shell(i.e explorer.Exe ) from msconfig>system.Ini to notepad...
That way only notepad will open when u start ur comp...Just tell ur bro..That u donno how it happend..(remember to back up ur system.Ini file before u do ne modification..)
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 02-10-2007, 10:04 PM   #19 (permalink)
damn busy...
utsav's Avatar
Originally Posted by Desi-Tek.com
download virus?
its a good option but it will prevent u also from using ur pc
one option is there.download the BSOD screensaver and put it in startup.it will run when any1 starts the pc and u tell them that ur PC is Damaged and u shut down ur pc.it might work
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 02-10-2007, 10:08 PM   #20 (permalink)
do jhapad laga kud comp use karna chodd dega.
try this.
SunnyChahal is offline
Old 02-10-2007, 10:24 PM   #21 (permalink)
Wire muncher!
infra_red_dude's Avatar
lolz... what questions.. what answers.. i'm amused!!
seriously, there's no better solution than being frank and explaining things to him! coz all the things you do are just temporary solutions. sooner or later they'll be breached and it'll be the same story again.
infra_red_dude is offline
Old 02-10-2007, 10:28 PM   #22 (permalink)
yeah,
but using linux may help.
but a big problem arises if the admin of the comp doesnt know how to use linux.
Old 02-10-2007, 10:31 PM   #23 (permalink)
Wire muncher!
linux? naah... then his cuz will be behind his arse to teach him linux!
Old 02-10-2007, 10:32 PM   #24 (permalink)
The Frozen Nova
casanova's Avatar
Just switch off the button at the back of your cabinet. Whenever, he would try to start your comp, it won't and whenever you want to use just remember to put that button back on.
Also, keep saying that your computer is giving problems. It doesn't start up easily. I think there are probs with RAM or SMPS. Keep cribbing
www.nerdweed.blogspot.com
casanova is offline
Old 02-10-2007, 10:33 PM   #25 (permalink)
big prob.
me keh raha hoon,
kaan ke niche do lagao,shanti se side me beth jaayega.
Old 03-10-2007, 06:06 AM   #26 (permalink)
clmlbx's Avatar
I would say just let him use the computer after his work is done then do some mischief ( so windows can not start ) and then blame him for ur doings and make it very big issue saying hime u just crashed my pc now I have to reinstall os all my data has lost ,now I have to waste my 2-3 hours on it ,ur work is delayed and so.................. .Do it two-three times, ok he is very smart and........so do it 4-5 times and over he will never return to u.
if then too he return then just say no to him defining ur self that u allways crash my pc , u don't know how to use it , then it take my 2-3 hours so I am not going to let u use my computer .
chapter close
you win
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 03-10-2007, 06:39 AM   #27 (permalink)
The blackhole®
desai_amogh's Avatar
few good answers ..
try this.
big prob.
me keh raha hoon,
what kind of cousin do u have.. does he stay with u & ur family?? or he visits ur house often ??
AMD Athlon II X4 635, MSI 880GMA - E45, Corsair value 2GB x 2, FSP Saga II 500W, APC UPS 600VA, Zebronix Bijli, Logitec Classic Mouse and keyboard
Lumix FZ35 Camera
Blog@ http://amoghdesai.com
+1 < click here to Rep me if I was helpful !
desai_amogh is offline
Old 03-10-2007, 12:54 PM   #28 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
never mind all the guys making fun of u.. tho the situation is really funny but i can somewhat relate to it.
the best option is to -
1. do a multiboot with a blank OS (linux, win98,winxp) such that u dont get the option to boot from or real OS in the boot up sequence. This can be done in may ways.
i) if u have two hdd then it can be changed from bios.
ii) if u have one hdd then use the active partition flag
iii) in case of one hdd Keep a 98/xp bootable disk and when u need to use the system boot using the disk and reset the active partition. in case of multiple hdd change it from the bios
->dont forget to password protect the bios with diff admin and user pass. if ur cousin asks then givethe user pass. he wont be able to change settigs then. if he protests just say u dont knwo what the prob is.
2. Add preventive methods
i) Use some utility to force a shutdown after 20-30 minutes of boot in the blank OS. u can alternatively set it up using even manager and shutdown command.
ii)do not install anything in the blank OS
iii)remove the default OS games too. i would remove notepad and mspaint too
iv) do more stuff like this
3. In ur blank OS use a limited a/c as default and disable the admin a/c. also create a odd name a/c like asppoweruser or winserviceuser etc with a heavy password. now only u know the a/c name and its pass and anyone seeing it wont easily guess that it is a proper a/c
4. In the blank OS(say XP) hide all ur partitions except the blank OS one. basically use software like folderlock or use mycomp> rightclick> manage> diskmanager> right click all partitions one by one and remove the drive letter. Now the normal non-admin user cannot view the partitions not can he change it in the drive manager.
5.The most important part for this elaborate setup to succeed is your acting! you have to behave dumb so that the other guys cant guess what u have done. u have to behave innocent and stupid.
Finish! The -The BlacKCoaT Operative- delivers one again
Rollercoaster is offline
Old 04-10-2007, 04:45 PM   #29 (permalink)
amanjagga's Avatar
chapter close
you win
Already applied this trick
But he is..............................
and come backs again and i cant stop him due to family relations
Originally Posted by desai_amogh
few good answers ..
No he does not lives in my house
But come to my house daily (mere jaan khane ke liye) just sharing my grief
www.hhostingg.com
Old 04-10-2007, 06:59 PM   #30 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Gud ideas…Guys…………………..
Hey buddy….
You can change the settings in the BIOS and mk it “Boot From CD Rom” instead of “Boot From Hard Disk”……..
Make A Shortcut of this command and put it in the startup………..
%windir%\system32\shutdown.exe -s -t 3 -c "Your Computer is infected with serious virus. Pls switch off Your Computer"
A simple Solution:-
Your Cousin may be a kid who likes to play game or run some programs………..Delete the games……..or request him only to play Games only..….not to change the settings of the PC……Lock the C:\ ….D:\.......E:\.......and so on………Make a Folder in the desktop.......And add all the shortcuts of the games in that folder….……….Tell him coolly by giving a\ chocolates…..or anything he likes………Request him to play for a limited time……….otherwise Delete All the Games……Restrict each an every things…….i.e..
Restrict Display Properties:
Restrict right-click in Start Menu:
Restrict Taskbar Context Menu:
Restrict Users to enable New XP StartMenu:
Restrict Programs to run
Restrict Writing to USB Drives\ CD Rom
Restrict any Control Panel Applet in 2000/XP
Uncheck all the Start Menu Items like Run……Search…..etc…..
Restrict him to open My computer and Documents………..
And Act like a dumb……….As if U don’t know anything…………..
Tell Your Mom and ur aunt…..Computer is infected with a serious Virus and needs to be formatted……………………Heeeeeeeeeeeeeeeee
And hey if u don’t want ur Mom to shout at u……then dont slap him!!!!!!!!!
||uLtiMaTE WinNER||
Ron is offline
needed 2 buy a good camera????? help needed.. The Day Walker! Cameras and camcorders 5 02-07-2005 04:43 PM
- by Piyush
