Old 15-03-2005, 02:24 PM   #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Urgent: HDD master slave errors on 98
One day I took my 80GB HDD to a friend who has a 40GB HDD. Both are of Seagatte but mine is UATA drive.
My Friend's PC:
P4, 128MB DDR 226 RAM, 52X CD ROM and Windows 98.
When we made my drive as slave it did not detect at first but was able to do so after some time. But suddenly the Windows hanged and it is giving problem afterwards. Also to tell you my drive has 2 NTFS and 2FAT32 partitions. After restarting it sometimes goes to safe mode, sometimes does not boot, sometimes automatically restarts. For making the we had to remove CD and then we joined the slave.
Now we removed the slave and now the computer detects the 40GB as primary but CD as secondary slave instead of Secondary master. Also after the 98 boot up screen it shows the error:
VKD driver initialisation problem:
Windows Protection error. Now we are stuck here. Also 98 bootup menu also shows up but ultimately this error icomes everytime.
Error message may had diff statement.
Help? Urgent[/b]
navjotjsingh is offline
Old 15-03-2005, 03:03 PM   #2 (permalink)
first check jumper setting for master slave configuration .
if it doesen't work try to overwrite 98
and
even after it does't work
your 98 must be currepted so you have to reinstall it with format.
parth is offline
Old 15-03-2005, 06:09 PM   #3 (permalink)
I am Optimus Prime
what do you mean by overwriting 98?
- by Piyush
