Old 30-09-2007, 07:18 AM   #1 (permalink)
Default Help Cant View Hidden Files
hi guys.....
m struck in dis big mess......
actully there ws a worm in my comp which opened drives into new windows n hd disables the search option along wid corruptin windows media player .......
it wsn`t allowin me to del autorun.inf file also.....
thnx to Nod32 antivirus......i gt rid of dis bullshit......
bt one prob still remains intact.....
I M NOT ABLE TO VIEW / ACCESS HIDDEN FILES AND FOLDERS....
AS SOON AS I GO TO TOOLS -> FOLDER OPTIONS -> SELECT ON VIEW HIDDEN FILES/FOLDERS......IT ROLLS BACK TO DO NOT SHOW HIDDEN FILES AND FOLDERS......
m totally bugged by it......
cnt find a soln 4 it n hv tried diff. antiviruses n spyware removin tools bt all in vain.......
Pls
help !!!!!!!!!
Thnks in adv.
amancoolguy777 is offline
Old 30-09-2007, 07:45 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Help Cant View Hidden Files
Maybe its just a registry trick?
User Key: [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\
Advanced]
Value Name: Hidden
Data Type: REG_DWORD (DWORD Value)
Value Data: (1 = show hidden, 2 = do not show)
Set the key or create it appropriately.
Via http://www.pctools.com/guides/registry/detail/1007/
QwertyManiac is offline
Old 30-09-2007, 11:12 PM   #3 (permalink)
thnx a tonn 4 rplyin.......
tried it.....bt of no avail.......
it shows hidden files once bt as soon as i click on do not show .......
it does allow me to show thm next time frm da option "show hidden files" and rolls back automatically.....
only way i cn view thm is by chngin dis reg. key over n over again....
ne other permanent soln to it?????
pls help....
Old 30-09-2007, 11:24 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Try this
Go to :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\Advanced\Folder\Hidden\SHOWALL
CheckedValue
reset it back to 1 from 2. ( to do that right click CheckedValue>modify>value data >
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 30-09-2007, 11:32 PM   #5 (permalink)
Commander in Chief
Something malicious must still be running. What were you infected with?
Old 01-10-2007, 01:25 PM   #6 (permalink)
Thumbs up Re: Help Cant View Hidden Files
THANKS A TONN CYBERBOY !!!!!!!!
PROBLEM RECTIFIED........
VALUE WS PLACED @ 0 INITIALLY.......SO ROLLING IT BACK TO 1 SOLVED THE THING IN THE REG ENTRY U MNTND......
OH.....btw sir i ws infectd wid these 2 trojans.....
avpo.exe - Win32/PSW.Agent.NDP trojan
ntde1ect.com - Win32/PSW.Agent.NDP trojan
THANKS A LOT .........BOTH OF U GUYS ROCK !!!!!!!!!!!!!!!!
CHEERS !!!!!!!!!!!
Old 01-10-2007, 02:59 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
welcome
zyberboy is offline
View/Add hidden files/folders in Nero g_goyal2000 Software Q&A 4 25-05-2008 08:27 PM
Unable to view hidden files captainshailendra Software Q&A 1 18-06-2007 03:43 PM
Where are my hidden files ???????????? jayanbhm QnA (read only) 1 06-06-2007 01:09 PM
Fresh View -organize & view multimedia files s18000rpm QnA (read only) 4 29-12-2006 08:14 PM
- by Piyush
