15-03-2005, 12:33 PM
Resizing Partitions.......
Plz tell me how can i resize partitions WITHOUT any loss of data.........
Thankx in advance !!
15-03-2005, 12:48 PM
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
15-03-2005, 01:22 PM
Ignorance is BLISS !!
U Can use Norton Partition Magic !
15-03-2005, 07:13 PM
Hi
Why dont u try Partition Magic...?
Regards,
Ramprasad
16-03-2005, 12:48 AM
Its Sucks If u Do A single Mistake,You Will Loose All your Data,So Remember That Before using It,
16-03-2005, 06:44 AM
[b]
U know somethin' player !
Resizing partitions is not for fun, is it ?
U always gotta be careful !
Any way..................
Does any1 has better solutions ?
16-03-2005, 11:19 PM
hey man,
try using partition magic ,it is very simple
it works abs. fine
16-03-2005, 11:23 PM
partition magic is THE BEST solution..
before making changes it shows u what ur new partition would look like.. simple to use
I\'M BACK
16-03-2005, 11:34 PM
If u say part-magic is waste and it is erroneous.. your views are wrong.
U need to be patient and careful. U press the button thts why it goes wrong to you, but the program functions corectly
16-03-2005, 11:45 PM
I tried installing Partition Magic 6 by Power Quest and this is the message I got:
Partition Magic 6.0 has a known compatibility issue with this version of Windows and might not run as expected. This program has difficulties with NTFS partitions. For more information, contact PowerQuest.
Is this normal?
Hard work never killed anybody..........But why take the RISK
17-03-2005, 12:10 AM
Latest version is 8 or 9 iam not sure.Old versions are not taken into account ..... when u rely on crap cds this is wat happens
17-03-2005, 04:28 PM
D00ds, I need something that is efficient, reliable & most importantly under 5 Mb in size....................
18-03-2005, 11:24 AM
C'mon people, you can come out with better softwares !!
18-03-2005, 12:12 PM
mekalodu
i didnt have any problem while using it ..... can u explain what mistake u r talking abt so the everyone can know where it sux ...
mekalodu
18-03-2005, 12:23 PM
CAN ANYBODY PLEASE SUGGEST A GOOD SOFTWARE FOR RESIZING (UNDER 5 MB) WHICH CAN DO THE JOB FOR ME !!
18-03-2005, 12:31 PM
If you dont have data on the partition, or if the data is useless to you, use Ranish Partition Manager, else, you have to use Partition Magic, no other way out to non-destructively change partitions.
Playing FEAR XP/LSW2
18-03-2005, 12:45 PM
O.k.
Thankx every1 !!
18-03-2005, 01:17 PM
#19 (permalink)
@nipun_the_gr8
try this ...its under 5MB
http://www.ranish.com/part/
@indrajit
u were trying to partition in winxp ?? its not possible with PM6 ,hav to go for PM 9 for that
18-03-2005, 01:19 PM
#20 (permalink)
@blacklight: Ranish Partition Manager is not non-destructive. I told him to use it if he didnt worry about his data integrity.
18-03-2005, 02:42 PM
#21 (permalink)
@enoonmai
u r right enoonmai ,he needs to use Partition Magic .if he needs his retain the data.and its way bigger than 5 mb
Search this Thread |
