Hi!
Firstly if this is the wrong section for this question then sorry.
I was trying to make some vedio dvd using nero vison so that they can be plackback by normal dvd player but the problem is that the file contain error so while transconding process of nero vision it get aborted in between so is there any software which can correct them or can do the error correction on the fly & write in the dvd. I need some good s/w so that i can get the best quality.
Thanks in advance..................
