Old 26-09-2007, 09:04 PM   #1 (permalink)
fakkadbaba's Avatar
Angry Unable to See "Local Settings" Folder
I am unable to see the "Local Settings" folder in 'My Documents' even after choosing the option of seeing hidden files and folders. I can't even find it with the 'Search' option. What has happened????? and what is the solution????? Plz help.
fakkadbaba is offline
Old 26-09-2007, 09:52 PM   #2 (permalink)
slugger's Avatar
Default Re: Unable to See "Local Settings" Folder
location of local settings folder
c:\Documents and Settings\Username
where Username stands for your profile username
c:\Documents and Settings\Default User
slugger is offline
Old 27-09-2007, 10:13 PM   #3 (permalink)
fakkadbaba's Avatar
Unhappy Re: Unable to See "Local Settings" Folder
Probably I was vague in putting forth my problem. I am aware where to locate the 'Local Settings' folder, but now I am not able to 'see' it, not even through 'Search' from the 'Start' menu. I think it has happened after I installed ZoneAlarm and Ad-Aware SE personal. Is it in any way related to this action???
Old 28-09-2007, 05:24 PM   #4 (permalink)
You can try another explorer software like Explorer XP.
ThinkFree is offline
problem in "view" of "folder options" mind021 QnA (read only) 5 23-01-2008 01:43 PM
Pen drive error messg"Unable to open Script file "F:\MSDLL.dll.vbs" janitha Software Q&A 19 20-04-2007 10:25 PM
Unable to transfer "large" files to J300i enzoferrari Mobiles and Tablets 2 24-03-2006 07:59 PM
can't name a folder "con" or "lpt1" club_pranay Software Q&A 1 23-11-2005 03:14 PM
help me 'unhide' the local settings folder... anandk QnA (read only) 1 02-08-2005 08:28 PM
- by Piyush
