Old 24-09-2007, 01:43 AM   #1 (permalink)
Question DAA file extension
Does anyone know of any freeware to open DAA images. i.e. OTHER than power iso.
The 'free TO download' 30-day trail is crippled at around 300 mb. So, it's pretty useless. Well...
asangba is offline
Old 24-09-2007, 01:49 AM   #2 (permalink)
slugger's Avatar
Default Re: DAA file extension
DAA file format is a proprietary format of d Co dat developed PowerISO
AFAIK no other sw present dat can open it other than PowerISO
u may wan2 try WinRAR/Zip (tho not likely to work)
this thread must be moved to QnA
REPORTIN
slugger is offline
Old 24-09-2007, 02:56 AM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
as its proprietary format so they are owner of it, you only have to use PowerISO
but you can convert it to *.iso and burn it as you like
but the catch is its not possible in trial period & burning the disc from it may the option but i remond you convert into *.iso
gary4gar is offline
File & Extension Ron Tutorials 6 26-02-2007 04:02 PM
Unknown file extension dissel QnA (read only) 3 31-01-2007 01:11 PM
Know each and every file extension ashisharya Tutorials 3 19-12-2006 12:32 PM
Is there any way to google for perticular extension file ?? virus_killer Internet & WWW 4 22-10-2006 10:35 PM
.gsd file extension debfromhell Software Q&A 1 11-08-2006 01:44 PM
- by Piyush
