Old 22-09-2007, 08:18 PM   #1 (permalink)
sourav's Avatar
Default how! to make a infrared 'transmitter'
i want to use a remote controller of a device from another room which is far away.
is their anyway? please sugget.
i think we can take a infrared receptor & infrared bulb. I know infrared receptors are available at stores. We have to make make a circuit through which we can utilise this to control other devices.
e.g-:> I mean I have tatasky located in one bedroom with the tv. it is connected to computer through rf(cable line) and to the tv with audio video channel available. I want to control the tatasky while watching it on tatasky.
I hope u understand my question
pls help
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 22-09-2007, 08:21 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: how! a infrared 'transmitter'
setup a mirror arrangement to relay the infra red .... but i doubt the possibility to achieve somehting like this ...
http://beingmanan.com
iMav is offline
Old 22-09-2007, 08:35 PM   #3 (permalink)
bro... i dont think you can use IR for transmission from aroom to another. its usually point to point communicator and from room to room ... no way !! yea... may be mirror arrangement might work ( im not sure ) .
but you could use a bluetooth transmitter ... the ics are available ... but this project migt turn out costly !!
abinesh is offline
Old 22-09-2007, 09:22 PM   #4 (permalink)
sourav's Avatar
think i press a switch on the remote of tatasky while sitting near the computer. By having a receptor in that room, connected to a a circuit which boosts the signal and sends that signal (through wires) to the room where it is located. And keeping a infrared bulb infront of the the tatasky, so that when i press the key to change the channel, it transmits the data to that bulb located infront of the tatasky can change the channel by transmitting the same signal.
What do u think ???
oye help karo
sourav is offline
Old 22-09-2007, 09:31 PM   #5 (permalink)
No longer here..
I actually wanted to setup something similar.I have DishTV in the drawing room and have the audio and video cables from the Settop box to the tv tuner in the bedroom.I think the following might work ....
You can get a infrared transmitter the same as the one in your remote and place it directly infront of the Settop box's infrared receiver.Now connect the wires from the transmitter to the infrared tarnsmitter on ur remote.I am talking about a parallel connection.It should work I suppose and will not need any extra boosting.What basically u r doing is extending the remote transmitter to beyond its original length.
Now I havent tried it ..... But wish to in the future.
I ll try it on monday .....lets see
indian_samosa is offline
Old 22-09-2007, 09:42 PM   #6 (permalink)
iMav's Avatar
^^ better than that .... remove the ir transmittter frm the remote ... connect to a wire and place it in front of ur set top box ....
iMav is offline
Old 22-09-2007, 09:44 PM   #7 (permalink)
sourav's Avatar
now think again,
it will need electricity to provide reception of remote signal and transmit it to the bulb.
so, their is a need of circuit system. i want to know on how to make that circuit.
sourav is offline
Old 22-09-2007, 09:53 PM   #8 (permalink)
iMav's Avatar
it will work on the power by the remote only ....
iMav is offline
Old 22-09-2007, 09:56 PM   #9 (permalink)
sourav's Avatar
i don't want to open the remote and place.
i want remote and the receptor should not be connected by wires
sourav is offline
Old 22-09-2007, 10:20 PM   #10 (permalink)
No longer here..
yup that also will do .... But Khali-pili why to remove the nice transmitter on the remote !!
Old 22-09-2007, 10:22 PM   #11 (permalink)
sourav's Avatar
^^ i agreehow can u remove it from it! (don't ans this question)
we need a ciruit
help me plz
sourav is offline
Old 22-09-2007, 10:46 PM   #12 (permalink)
iMav's Avatar
circuit for what dude making a power ckt for a ir tx wont help at all
u need to relay the signal coming from the remote
iMav is offline
Old 22-09-2007, 10:52 PM   #13 (permalink)
Wire muncher!
infra_red_dude's Avatar
first of all you can just take a transmitter and connect it to the receiver by a simple wire. you require a modulating circuit to convert the IR signal to electrical signals and then back to IR signals. this aint an easy job man! i don't think working that much wud be viable. IR needs line of sight. a major drawback. this is the reason why IR is not popular (yeah mebbe even me!! )
infra_red_dude is offline
Old 22-09-2007, 10:54 PM   #14 (permalink)
sourav's Avatar
i mean that only
i want to relay signal but i don't want to open the remote make relay connection. So, their is a need of a circuit which accepta the signal and send to the bulb for this it also need electricity
so whatever u can call it but i can't open my remote as it will make the remote look bad and it will not be allowed by my family and this will also hamper warranty
@infra
but i have to use this all remote suport IR only
sourav is offline
Old 22-09-2007, 11:00 PM   #15 (permalink)
iMav's Avatar
nahi chalega bhai ... ir relay cant be done at home ....
iMav is offline
Old 22-09-2007, 11:01 PM   #16 (permalink)
sourav's Avatar
plz help
sourav is offline
Old 22-09-2007, 11:01 PM   #17 (permalink)
Google Bot
Pathik's Avatar
the best option wd be to use an array of mirrors.. Position them such that the signal get reflected directly onto the receiver.
Pathik is offline
Old 22-09-2007, 11:01 PM   #18 (permalink)
Google Bot
Pathik's Avatar
Pathik is offline
Old 22-09-2007, 11:07 PM   #19 (permalink)
sourav's Avatar
nothing is impossible
just changing of the IR signals are done in tv on anything which uses remote
so, their should be a wayout, i want just a circuit diagram
off topic
are there any electrical engg or students here
sourav is offline
Old 22-09-2007, 11:08 PM   #20 (permalink)
meowww meoww
Kenshin's Avatar
get the ir signals modulate them use a RF transmitter ....receive the RF signals by a receiver demodulate...giveem to the IRLED simple....will work in 200 mtr range.....will cost u 600 bucks tho.Am a electronics engg student...rt now am doin a project on transmiting temperatures from 6 different points thru a microcontrolled RF transmitters to a PC.
"Microsoft: You've got questions. We've got a dancing paperclip."
Have fun,no worries..
Kenshin is offline
Old 22-09-2007, 11:12 PM   #21 (permalink)
Wire muncher!
you don't need to open up the remote. you need to get a set of IR transmitter and receiver. then you need to wire them up wid 2 circuits. the receiver is connected to the circuit which converts IR signals to electrical pulses. this sits near ur computer. the output of this circuit goes to the input of another circuit which converts electrical signals to IR signals connected to the transmitter which sits in front of the IR receiver on the set top box. yes, the whole circuit will require power, DC power (mebbe an adapter or batteries).
but believe me, its not easy to build this circuit. jus go out in the market and launch a hunt for those kindsa circuits.
Old 22-09-2007, 11:14 PM   #22 (permalink)
meowww meoww
Kenshin's Avatar
^^ That will be messy stuff.....its cheap but its no good...i hv worked with IRs and they are no fun to work with....tats why now i hv shifted to RF in all my works...except linefollowers and to control my PC ka apps using tv remote hehe
Kenshin is offline
Old 22-09-2007, 11:17 PM   #23 (permalink)
sourav's Avatar
can u plz give a circuit diagram as i unable to make out
how to modulate and demodulate ir signals to rf and vice versa
sourav is offline
Old 22-09-2007, 11:19 PM   #24 (permalink)
Wire muncher!
^^^ you get readymade circuits for that.
@yeah kenshin, i kno that too. am an electrical and electronics engg. plus hey i'm the IR of this forum!!! who better can know the pains associated wid me!!! haha...
Old 22-09-2007, 11:25 PM   #25 (permalink)
sourav's Avatar
@infra
that is what i want
i don't want to make the circuit but just wanted this working
do u know, what are those circuits called
are they available in any electrical stores
can u also give the circuit diagram of connecting the battery, those circuits, transmitter and receiver
sourav is offline
Old 22-09-2007, 11:25 PM   #26 (permalink)
Wire muncher!
well, i can't say where they are available or how easily. you gotta hunt for them or get them made from the electronics hub in ur city.
Old 22-09-2007, 11:25 PM   #27 (permalink)
meowww meoww
Kenshin's Avatar
Get a TSOP1738....since most IR remotes work at 38KHz...this receiver has 3 pins...one of it is the data...give this data pin to a rf transmitter TX433...
this will transmit the data......recive the data using RX433
this has a data pin...give it to a IR led infront o ur tata sky.......press ur remote see it work ..
the RF modules will cost u bout 500 bucks...
Kenshin is offline
Old 22-09-2007, 11:28 PM   #28 (permalink)
Wire muncher!
kenshin forgot the IR transmitter on the other end. so add that
Old 22-09-2007, 11:31 PM   #29 (permalink)
meowww meoww
Kenshin's Avatar
Yeah a transmitter from the data pin...
Kenshin is offline
Old 22-09-2007, 11:34 PM   #30 (permalink)
sourav's Avatar
you mean that i will connect receiver's data channel to transmitter's???
if yes, then what are those other 2 point for, where they will be connected and how
then what about connecting the data pin directly to the data pin of transmitter
sourav is offline
FM transmitter? seriuslyblack Mobiles and Tablets 3 10-06-2007 12:43 PM
fm transmitter nipun.naik Mobiles and Tablets 5 09-06-2006 12:29 PM
infrared help neeeded.... angel QnA (read only) 10 14-12-2005 11:59 PM
ipod FM transmitter gdatuk QnA (read only) 4 20-09-2005 10:35 PM
Infrared Communicaton sid_b6505 QnA (read only) 9 05-08-2004 10:16 PM
- by Piyush
