Old 22-09-2007, 06:42 PM   #1 (permalink)
Default How to Install 2 Hard Disks?
I want to recover the data of a corrupted hard disk. When I connected the HDD to a good computer it does not boot at all.When I use only one HDD it boots normally.I have used the jumper settings of the corrupted HDD as slave . What other things to be considered before installing the 2nd HDD.
suniltr77 is offline
Old 22-09-2007, 08:38 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: How to Install 2 Hard Disks?
1. Set the bad disk as slave by not putting any jumper clip and connect the IDE cable.
2. Check whether the power cable to the bad hard disk is connected properly. I know many people who forget that
3. Power on the system and go to the BIOS by hitting del (or F2, depends on your motherboard)
3. See if the bad disk is getting detected or not in the first place. If it is not showing in the BIOS, press F10 to save and exit and get professional help, I don't think there's much you can do.
4. If you see the disk then set the booting hard disk as your good hard disk, press F10 to save settings and press enter
NucleusKore is offline
Old 22-09-2007, 08:51 PM   #3 (permalink)
slugger's Avatar
check the BIOS to c dat d existing HDD of d good computer is not working as a slave. If it is then put ur own HDD as the Master and set the slave as the first boot device (HDD1, i think)
slugger is offline
Old 22-09-2007, 09:08 PM   #4 (permalink)
sourav's Avatar
@slugger
please try to type more.
as it becomes difficult by some to understand ur easily, like me.
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 22-09-2007, 09:55 PM   #5 (permalink)
"The Gentleman"
vish786's Avatar
@thread starter,
its jumper settings problem, set one as master(see ur hdd labels its given how to use it) and other by slave my remove short pin.
and check ur bios and see that ur master should be first drive to boot.(this feature is available only on recent bios... so check it, if u hav one. )
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 22-09-2007, 10:09 PM   #6 (permalink)
The Devil's Advocate
iMav's Avatar
best .... set it to cable select and connect the hdd u want to boot ith to the second connector and the 1 want to copy the data from to the first connector
http://beingmanan.com
iMav is offline
Old 22-09-2007, 10:14 PM   #7 (permalink)
"The Gentleman"
vish786's Avatar
no cable select does not work on few systems... i tried it.
- Dijkstra
vish786 is offline
Old 23-09-2007, 05:17 AM   #8 (permalink)
I already set the bad HDD as slave.Power was connected.In Bios it shows only 1 Disk(the good only) If I try to find then also it unable to detect the bad one.When I connect the the bad only to the comp. boots properly(due to corrupted windows doesn't start properly). I don't understand why it is not detecting the 2 simultoneously while it detects each one individually.
Old 23-09-2007, 09:50 AM   #9 (permalink)
slugger's Avatar
do 1 thin, attach both the HDDs in d same config as it is wen u r shown only 1 HDD in the BIOS (d gud 1)
go 2 d BIOS and c weather d detected HDD is a msater of slave
den take out d gud HDD and boot usin d corrupt HDD (dont change ne jumper settings, just leave it as it is)
since u say it is also gettin detected, go to d BIOS and see wat is it a master or slave (both HDDs cannot be set to the same - Master or slave)
slugger is offline
Hard Disks for Laptops blacklisted Hardware Q&A 4 25-09-2007 06:34 PM
BAD HARD DISKs??? anilmail17 Hardware Q&A 2 29-03-2007 08:42 AM
Linux and Hard Disks The Unknown Open Source 9 21-02-2007 07:26 PM
Hard Disks: IDE vs SCSI synecdoche QnA (read only) 1 07-09-2004 05:18 PM
- by Piyush
