Old 21-09-2007, 07:18 PM   #1 (permalink)
Default info.exe
My computer copies info.exe to pendrive:\recycled\ folder and autorun.inf. I have AVG latest with me but nothing is detected. Kindly suggest
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 21-09-2007, 09:18 PM   #2 (permalink)
Nav11aug's Avatar
Default Re: info.exe
infected. Get Avast from http://www.avast.com and schedule a boot time scan
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 21-09-2007, 10:33 PM   #3 (permalink)
These are usb viruses which are auto copied when u connect to a system
Go to tools>folder options>view>
enable show hidden files & folder
un check hide protected OS files
Now search all root drives including ur usb drive which infected the comp & delete all "auto inf" files from it........................that should get you rid of this virus.
ranjan2001 is offline
Old 21-09-2007, 11:10 PM   #4 (permalink)
Not working.
Regarding avast.. the free version is very limited. I'm on a dialup and downloading a software and the updated may take long. I wonder if theres any manual way or single file removal type ... something like brontok washer?
valtea is offline
Old 21-09-2007, 11:15 PM   #5 (permalink)
What is not working??
Follow the steps & u definitely find the inf files.
Old 22-09-2007, 10:21 PM   #6 (permalink)
Try sysinternals autorun and process explorer. I am sure you can solve your problem by yourself
Sheik Rasheed K
Don't accept anything that costs joy.
Sheik Rasheed K is offline
Old 24-09-2007, 05:52 PM   #7 (permalink)
Just finding out autorun.inf and deleating those did not work. I think now my svchost is infected. So i was thinking if someone know a good removal so that i dont have to reinstall windows
valtea is offline
Info about PS2??? go4saket Gamerz 24 02-06-2007 01:06 PM
Need Info abt PHP nareshwithu Open Source 14 17-05-2007 03:08 PM
Wii Info shellgame Gamerz 9 10-07-2006 12:25 PM
Need More Info whistler QnA (read only) 2 10-05-2005 11:44 PM
- by tkin
