Old 14-03-2005, 01:34 AM   #1 (permalink)
Laptoping
Sourabh's Avatar
Default First Pictures of the XGI XG47 Graphic Card
The XG47 is an upcoming 3D Graphics Solution from XGI.
Specification:
* Shader Model 2.0
* Performance 3D graphics solution for low-power PC
* CoolPowerâ„¢ management (7.5 watts maximum dissipation)
* Power supply: 1.0/1.2v, 1.5v, 1.8/2.5v and 3.3v
* 40 million transistors in 0.13um CMOS process
* Standard 696 PBGA package (31mm x 31mm)
* PCI Express Interface
* Up to 300MHz engine and 350MHz memory clock
* Pixel fill rate: 600 million PS-shaded pixels per second and
1.2 billion flat-shaded pixels per second
* Texel processing rate: 4.8 billion texels per second
* 5.6GB per second memory bandwidth
* 64-bit Double-Data Rate (DDR) memory at up to 700 Mbps
* 256 MB frame buffer size
* Flexible frame buffer configuration with local memory and
Shared system memory
info from here
Sourabh is offline
Old 14-03-2005, 01:59 PM   #2 (permalink)
This is seriously underpowered man.. jus 5 Gbps..
..::The Slam Team::..
Slam Team is offline
Old 14-03-2005, 02:27 PM   #3 (permalink)
gxsaurav
Posts: n/a
This due to it's low performance & profile, will appeal a lot to the OEM sector, & office PCs, as this is compatible with Longhorn UI
Old 14-03-2005, 05:34 PM   #4 (permalink)
Yeah certainly... due to the so-low b/w..it shud surely be a good option for low budget users...
Old 14-03-2005, 08:39 PM   #5 (permalink)
Laptoping
Sourabh's Avatar
guys its meant for a cheap pci-e gfx card solution
this card wod be real cheap, something which anyone can buy
i think if it comes in india it wont cost more than 2000 Rs
Sourabh is offline
Old 15-03-2005, 02:55 AM   #6 (permalink)
Yup , the flagship cards from XGI , Volari DUO or something is just not capable enough to go headon with Nvdia and ATI flagship products .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
- by tkin
