Old 20-09-2007, 01:32 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Is it possible to send messeges to Seeders in uTorrent?
Hi Guys!
I am using uTorrent to doenload a few files (videos) adn unfortunately am stuck in 99.9%. Is there a way to send messeges to the seeders/peers, so that I can beg them to seed for some more time.
Chao...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 20-09-2007, 02:12 PM   #2 (permalink)
Default Re: Is it possible to send messeges to Seeders in uTorrent?
I am using Utorrent from 9 to 10 months but I don't think this is possible.....
to sent message to them because they are on different IPs and in utorrent only IP address is visible...........!!!!
meghraj is offline
Old 20-09-2007, 03:46 PM   #3 (permalink)
NP : Crysis
xbonez's Avatar
bitlord allows u to chat with others dl'ing or seeding stuff using bitlord
xbonez is offline
Old 20-09-2007, 09:58 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
....provided the other user is also using bitlord
NucleusKore is offline
Old 20-09-2007, 10:18 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Since you say you're stuck at some percentage, it'd mean there are no seeders. How would you message a seeder when there aren't any? :-\
And 95%+ hangs are too common, generally due to a common missing piece between peers. Those torrents are of no use at all ..
QwertyManiac is offline
Old 20-09-2007, 10:19 PM   #6 (permalink)
NP : Crysis
xbonez's Avatar
haven't i clearly mentioned it??
xbonez is offline
Old 20-09-2007, 11:05 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
if u r downloading video files u can easily play those files using Gom player without any problem.....or use BS player
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 20-09-2007, 11:11 PM   #8 (permalink)
Pragadheesh's Avatar
Post Re: Is it possible to send messeges to Seeders in uTorrent?
even i had a similar situation few times... but wid the help of vlc u can be able to see almost the full video except the last few mins...
Pragadheesh is offline
Old 20-09-2007, 11:59 PM   #9 (permalink)
NP : Crysis
xbonez's Avatar
yeah, vlc is gud at playing incomplete files
xbonez is offline
Old 21-09-2007, 04:42 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
u cannot send mssgs ......... wait 4 some more days seeder might b available lateron .........
... W H O T ...
ax3 is offline
Old 21-09-2007, 10:54 PM   #11 (permalink)
NP : Crysis
xbonez's Avatar
dude, 99.9% pe it should work perfectly. try it with vlc player
xbonez is offline
Old 22-09-2007, 09:20 AM   #12 (permalink)
9437077259
go4saket's Avatar
Unfortunately the video I am downloading is in rar format and so I need the complete file.
Win 7 Ultimate
go4saket is offline
Old 22-09-2007, 11:15 AM   #13 (permalink)
ArZuNeOs's Avatar
go4saket
Just use winrar & Click on Extract
in the nxt window select "Keep Broken Files" in the bottom left corner
& SAVE SETTINGS
& it should extract it
Back to the world of realms
ArZuNeOs is offline
Old 23-09-2007, 07:23 AM   #14 (permalink)
Vivek788's Avatar
thats nice info...I had deleted many rar files that ended up at 99%..lemme try next time...
Vivek788 is offline
Old 23-09-2007, 10:02 AM   #15 (permalink)
slugger's Avatar
FYI d data downloaded thru d bittorrent is not transferred in sequential order.
it is downloaded in order of availablity of file parts
so u may have downloaded 99.999999999% of the file and still miss the startin portion of d file
slugger is offline
Old 23-09-2007, 11:15 AM   #16 (permalink)
Multicore Mutant
Thread starter, you should have read the comments before downloading the file, mostly those which are archived like rar, zip, iso, daa etc etc.. because these file are sometimes found to be fake, dummy files yeah you heard it right fake dummy files.
And some rar files are password protected with no password given. LOL.
I always read others comment before downloading torrents.
Recently torrentspy comments are disabled, now slowly moving to mininova.
Hackattack is offline
Old 23-09-2007, 11:55 AM   #17 (permalink)
slugger's Avatar
OFFTOPIC
@hackattack
d non-availability of seeders has got nothing to do with the fact that d file is a dummy file
even legit but rare torrents can face d same problems
and just bcos dey r being distributed as an *.rar or *.zip or *.iso does not mean dat it ihas to be a dummy file
linux distros are made avalable as *.iso files
so du dat mean dey r fake or dummy files
ur post tho factually correct is totally offtopic and does nothing to solve our thread starters problem
slugger is offline
Old 23-09-2007, 12:15 PM   #18 (permalink)
Multicore Mutant
I already said the author to read comments before downloading, which in 1st place would have saved his precious time.
Most of the times those are fake ones, not always.
Btw what torrent are you downloading. I might help.
Bitcomet has a chating option i think(not sure tho).
Old 23-09-2007, 12:16 PM   #19 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i have seen many fraud dummy files .
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
uTorrent help Cool Buddy Software Q&A 2 07-08-2007 02:24 PM
Help me use utorrent ajaybc Software Q&A 6 19-07-2007 07:44 PM
Seeders, leechers, peers? Simple_Graduate QnA (read only) 6 09-03-2007 02:09 PM
Utorrent wizrulz QnA (read only) 2 20-12-2006 10:16 PM
Utorrent gau_pppu Software Q&A 5 17-11-2006 06:44 PM
- by tkin
