Old 20-09-2007, 11:21 AM   #1 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default How to make my html programs open by default in notepad2
I am facing this problem recently.I usually use notepad2 for small changes in codes and so i want to add the nodepad2 icon on the open with option when i right click on some files say html or jsp.
Problem is if i do browse and select the position where notepad2 exists then also the change is not reflected in the open with window.. the same works for my laptop but not in my office comp..
what should i do
the.kaushik is offline
Old 20-09-2007, 11:28 AM   #2 (permalink)
slugger's Avatar
Default Re: How to make my html programs open by default in notepad2
go to
Start->Settings->Control Panel->Folder Options->File Types (tab)
select the extension that u wan2 open with Notepad2 from the list of extensions
when u do that, press the Change button
it will show u a Open with... window
select d program u wan2 open it with
Now it wil autoamtically open it with the program
even if u l8r chage d deafult openin program, u will still get dat program as an option in the context menu
slugger is offline
Old 21-09-2007, 03:53 PM   #3 (permalink)
it does not works buddy. after i select notepad2 and then i press ok and there notepad2 is not there...!!!!!!!!!!
Old 21-09-2007, 03:57 PM   #4 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
right click on any html file then select open with then select notepad OR if notepad is not there manually locate notepad.exe and then check 'always use the same program to open these kind of files'.then click ok and enjoy.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 21-09-2007, 10:39 PM   #5 (permalink)
Google Bot
Pathik's Avatar
right click>properties>open with>notepad>done
Pathik is offline
Old 21-09-2007, 11:09 PM   #6 (permalink)
Console Junkie
aditya.shevade's Avatar
But won't that mean that all html files will open in notepad2 by default? Even if you don't want to edit them?
--- Console Junkie
aditya.shevade is offline
Old 21-09-2007, 11:58 PM   #7 (permalink)
slugger's Avatar
once u associate notepad2 to open all html files, it will do so
but, if u just to open it with notepad to modify d code, den change back d association to sum browser
next time wen u wan2 open it with notepad2, just right-click on d file and in d context menu u will find d notepad option (it will basically show all programs dat was used to open dat particular filetype)
slugger is offline
Old 22-09-2007, 12:13 AM   #8 (permalink)
Console Junkie
^^ That is what I meant. Why to make default program notepad2?
Just add a registry entry to html filetype with the path of notepad2 in openwith context menu.
--- Console Junkie
Old 22-09-2007, 03:27 PM   #9 (permalink)
^^dude not everybody is a geek like you.
Old 22-09-2007, 05:44 PM   #10 (permalink)
Console Junkie
^^ Nor am I.... I read this somewhere.... long time ago when I used to use windows.
--- Console Junkie
Old 22-09-2007, 05:58 PM   #11 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Just follow this:
http://www.askvg.com/how-to-add-remo...context-menus/
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 22-09-2007, 09:14 PM   #12 (permalink)
Console Junkie
^^ Nice marketing Vishal
--- Console Junkie
Old 23-09-2007, 01:25 AM   #13 (permalink)
Microsoft MVP
^^ hehe
How To Make Ie The Default Browser karthik55859 QnA (read only) 2 07-07-2006 06:31 PM
help in changing the default for programs pauljose Software Q&A 3 26-02-2006 05:16 PM
Urgent: HTML Programs/Projects g_goyal2000 QnA (read only) 2 08-02-2006 07:42 PM
Urgent: HTML Programs/Projects g_goyal2000 Software Q&A 4 08-02-2006 10:13 AM
Make a folder in "start>programs" menu & move programs to it Aanand QnA (read only) 5 26-10-2005 12:25 AM
- by tkin
