Old 13-03-2005, 09:15 PM   #1 (permalink)
navneeth_snr's Avatar
Default Can't Create New Folders
Hi All,
I can't create new folders. When right click on desktop, the option "new" has been disabled. How to fix it and make it enabled! I can't create new folders from main tool bar also
http://www.geocities.com/navneeth_snr/untitled.bmp
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
navneeth_snr is offline
Old 13-03-2005, 09:39 PM   #2 (permalink)
NikhilVerma's Avatar
If you can then download "X-Setup" ... just Google it...
And then search it's tweaks for the string "New" and you'll find an option to re-enable the "New" tool....
It must be a spyware which did that so use anti-spywares like "Spybot-Search & Destroy" and Ad-Aware ...
NikhilVerma is offline
Old 13-03-2005, 10:40 PM   #3 (permalink)
Thanks Friend ! I have Pc-cillin 05, Yes it detected a spyware now when I scanned! SPYW_Coolsrch.A
I will download x-setup! Thanks once again!
Navaneeth
- by tkin
