Slugger he is asking how to implement registration using Inno Setup not to fix any unregistered dll file on PC.
Saurabh - there is a function in InnoSetup - Check help file of Inno Setup.
Excerpt from Inno Setup File
Find this help in Inno Setup Help File>>Pascal Scripting>>Support Functions Reference.
You need to learn how to implement Pascal Scripting in Inno Setup.
Prototype:
procedure RegisterServer(const Is64Bit: Boolean; const Filename: String; const FailCriticalErrors: Boolean);
Description:
Registers the DLL/OCX with the specified filename. If Is64Bit is True, the DLL/OCX will be loaded as a 64-bit image and registered in a 64-bit process. If FailCriticalErrors is True, the system will not display any critical-error-handler message boxes. Raises an exception if not successful.
Example:
begin
// Register hhctrl.ocx located in the System directory.
RegisterServer(Is64BitInstallMode, ExpandConstant('{sys}\hhctrl.ocx'), False);
end;Because we specify Is64BitInstallMode in the first parameter, it will register the 64-bit OCX in the 64-bit System directory when Setup is running in 64-bit mode. Otherwise, it will register the 32-bit OCX in the 32-bit System directory.
To unregister dlls use
Prototype:
function UnregisterServer(const Is64Bit: Boolean; const Filename: String; const FailCriticalErrors: Boolean): Boolean;
Description:
Unregisters the DLL/OCX with the specified filename. If Is64Bit is True, the DLL/OCX will be loaded as a 64-bit image and unregistered in a 64-bit process. If FailCriticalErrors is True, the system will not display any critical-error-handler message boxes. Returns True if successful, False otherwise.
