Old 13-03-2005, 04:33 PM   #1 (permalink)
Default which computer would be apt?
cud u tell me as to what config should be best for usage in an auto-emission testing centre in a fuel station? the cheaper the better.
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS...
BLITZ~KRIEG! is offline
Old 13-03-2005, 06:08 PM   #2 (permalink)
Ignorance is BLISS !!
Now common mate !
Ask us a better question than that !
This is no place 2 answer that S***
Go visit the Hardware section and ask the ppl there!
Don't bother us here
rajkumar_personal is offline
Old 13-03-2005, 07:14 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
@raj plz try avoidin such posts.. he is askin us a help so if u know the answer plz help else jus stay away m8
@blitz.. i suppose a normal PIV with say 128 mb is more than enuff.. as for the s/w am not sure of them.. will edit my post when i find sumthin good.. else jus take a walk down to the nearest emission center n check..
bharathbala2003 is offline
Old 13-03-2005, 08:54 PM   #4 (permalink)
The connectivity between the transducer and the PC is via the serial port and the application runs in MS Dos if i recollect correctly from what i saw at MG road Petrol punp today. So i recommend a p1/p2 system with 64Mb ram and say a 4GB disk This configration is available at Big Apple for Rs 3500/- (less Monitor +2500) check it out
http://www.bigapple.co.in
**** happens
pradeep_chauhan is offline
- by tkin
