Old 17-09-2007, 12:18 PM   #1 (permalink)
Smile Need Help
Dear Team
I had a problem from last one week as I try to delete a folder from my documents but its recreated after a day. I have Trend micro Antivirus with Windows XP Professional SP2 OS we don’t have client / server environment as all machine on workgroup.
Kindly revert the solution.
Regards
Vijay
vijay2u4u is offline
Old 17-09-2007, 12:31 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Need Help
Please let us know which folder you are deleting?
Kiran Kumar R
Kiran.dks is offline
Old 17-09-2007, 01:40 PM   #3 (permalink)
ajex's Avatar
and if there any process running from that folder???
ajex is offline
Old 17-09-2007, 02:35 PM   #4 (permalink)
Beware of the innocent
ilugd's Avatar
hijack this log?
Life is too short. Have fun.
ilugd is offline
Old 17-09-2007, 03:50 PM   #5 (permalink)
Smile Re: Need Help
This is just a Project folder which was created on 6 or 7 month before for the project purpose.
There is no such thing like hijeck coz this thing is happen on only one pc.
Though I check all the logs regarding the same.
Regards
Vijay
Old 17-09-2007, 04:42 PM   #6 (permalink)
piyush gupta's Avatar
No no..ilugd means to say
Post your hijack this log file here so that someone can help u.
Get hijack this from here
http://www.download.com/HijackThis/3...-10379544.html
and post your log file
piyush gupta is offline
- by tkin
