17-09-2007, 05:16 AM
Core 2 Duo vs Pentium 4 [question]
I am a total noob when it comes to hardware, and I just want to get this cleared up. The difference between Core2Duo and P4...
Which is faster, a P4 3.0ghz -or- a 1.66ghz Core2Duo processor?
Which one should I choose for a gaming? I want to play elder scrolls 4 oblivion...the minimum system requirements in terms of processors are 2.0ghzs P4 for that. Would a 1.66 C2D be good enough?
Thanks!
17-09-2007, 05:39 AM
I WANT MORE FPS!!
Re: Core 2 Duo vs Pentium 4 [question]
You can get 2.0ghz core 2 duo for less than 5.5k. Core 2 duo is faster because of its architechture and the fact that its a dual core processor. Pentium 4 is a single core processor and is slow, which is the reason why its so cheap. Actually it could be cheaper, but its out of mainstream production and hence the supply is down.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
17-09-2007, 05:48 AM
So you're saying a 1.66ghz Core2Duo is faster than a P4 3.0ghz?
17-09-2007, 06:20 AM
Commander in Chief
Let them fight!
[Processor comparison] between E4300 C2D and Pentium 4 530. The difference is more than half! (See the RED highlighted bars, and also see the performances for other modules available there)
And when it comes to applications, processor clock speeds don't matter. So even if you have a 1.5 GHz P4 and the game demands 2.0 GHz on the box, it'll run fine provided you got adequate GPU and RAM.
As some people say, basically 1.66 GHz C2D = 1.66 x 2 Cores = 3.32 GHz total > 3.0 GHz P4. Not logical enough but this sells C2Ds for Intel.
Harsh J
www.harshj.com
17-09-2007, 07:36 AM
TechTin.com
I think its not double speed.It is 40% more efficient.
17-09-2007, 08:26 AM
Originally Posted by QwertyManiac
Let them fight!
Thank you
17-09-2007, 10:05 AM
Commander in Chief
Yeah, debatable alright, subject to the work you give them.
Harsh J
www.harshj.com
17-09-2007, 04:09 PM
die blizzard die! D3?
never seen a game or an application which could stretch my cpu usage beyond 70-80%.I have a C2D e6300@1.86GHz(stock speed).
Stealing your women and horses since 1843.
17-09-2007, 06:08 PM
The Frozen Nova
Yes, the speed is not doubled. It depends how the proggies are written to interact with the CPU.
www.nerdweed.blogspot.com
17-09-2007, 07:05 PM
I ve both P4 2.8 GHz HT and C2D e6320
P4 produces a lot of heat and its fan is noisy..its runs normally at 60-70 degree Celsius whereas C2D is super cool in terms of performance and it runs at 40-50 degree Celsius ,subject to multitask work load and its best for gaming purposes go for it .
Be like a postage stamp-stick to one thing until you get there.
17-09-2007, 07:07 PM
Rubik's Uncle!!
^^^ Noise comparision P4 Vs C2D pls
17-09-2007, 07:21 PM
P4 2.8 GHz HT sounds like crazy ,one of my friends have P4 3.0 GHz his pc also sounds like hell and disturbing whereas C2D works like a charm.
There is also a workaround for reducing noise in P4 systems.
Actually the noise will not be noticeable till it gets old a little bit and is subjected to heavy games mine started crying after 1.5 years its obvious when you ve a proccy running at 60-70 degree Celsius the thermal paste isn't have much effect and starts to erode away.
So after one year of usage i would recommend P4 users to reapply thermal paste to make its breathing and cooling easier.
C2D is worth the money spend and i am completely satisfied with its performance.
17-09-2007, 08:47 PM
Alpha Geek Banned
man....... take it this way
u've got a bike(two wheeler) ... lets take VR 300 cc....... thats quite speedy n crosses 150...
now take a maruti 800...... it chokes out at 120 kmph....but power?.... maruti has more power ....
u wont even get that power by joining two bikes........ the same is the case with p4 n c2d....... lol
17-09-2007, 10:28 PM
Rubik's Uncle!!
@shashank thanks for informing. I too have a P4 520 and from past 1.5 year My neighbours can tell if I am using my system. I think its time for a thermal paste/cooler combo
17-09-2007, 11:27 PM
@charan
glad it helped you
19-09-2007, 04:55 PM
Cool as a CUCUMBAR ! ! !
opt 4 C2D .....
... W H O T ...
Search this Thread |
