Old 16-09-2007, 08:37 PM   #1 (permalink)
Chetan1991's Avatar
Question Data on DVD vanished!!!!!!
Guys, Once I scanned a Digit DVD with McAfee antivirus.After that, I saw only one folder in it, and on reopening,there was nothing on the DVD!!!!!!
I've also reinstalled my OS after that but still the DVD appears blank.Please help me.
Chetan1991 is offline
Old 17-09-2007, 01:18 AM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Data on DVD vanished!!!!!!
Probably defective media if it does not work in other dvd drives. I've had similar problems with Moserbaer DVDs, especially those written at 16x even when that speed is supported by the media. I wrote the data, verified it, put it away safely, tried to open it after a month, I get either crc errors or blank DVD.
NucleusKore is offline
Old 17-09-2007, 06:10 AM   #3 (permalink)
ArZuNeOs's Avatar
I do certain things
1) Always write at 4x speed...It takes 15 minutes for a DVD to be written on 1 gb RAM
2) For verification use another drive for checking it & use different sware like CD check....& not Verification mode on nero
& never use cheap DVD's ....Moserbaer ... & Japanese duos ...i trust them
Back to the world of realms
ArZuNeOs is offline
Old 17-09-2007, 01:37 PM   #4 (permalink)
ajex's Avatar
Try isobuster....a good sofware to deal with data recovery from the medias
ajex is offline
Old 17-09-2007, 01:43 PM   #5 (permalink)
Kiran.dks's Avatar
Did the DVD run well before Mcafee scan?
Kiran Kumar R
Kiran.dks is offline
Old 17-09-2007, 01:52 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
even i've had a couple of DVDs like this. no matter what i cudn't recover the data. finally i threw them!
infra_red_dude is offline
Old 18-09-2007, 05:33 PM   #7 (permalink)
Chetan1991's Avatar
Yeah,It worked fine before.
And to others who are advising me to write at lower speed,I'm talking about a Digit DVD,which is pre-written,provided with Digit magazine.
Old 18-09-2007, 05:49 PM   #8 (permalink)
Kiran.dks's Avatar
That's strange. I think it has nothing to do with McAfee scan. Some how the DVD is not in a workable condition-may be it has damaged.
McAfee can't remove/alter the DVD content because the DVD's provided by Digit is read only. So please check if other Digit DVD's are autoplaying well on your PC.
Kiran Kumar R
Old 18-09-2007, 10:30 PM   #9 (permalink)
TheSaint
Its a DVD problem similar to what I described above, except that it was provided by Digit. The Discs work for a while and then one day poof ! You'll just have to throw it out I'm afraid
@neogopu - I have seen that writing at 4x does help to avoid this problem, so far no DVDs I have written at 4x have given trouble.
Old 19-09-2007, 10:41 PM   #10 (permalink)
Chetan1991's Avatar
I've found out that the DVD is working fine on other computers!!!!!!
Old 19-09-2007, 11:16 PM   #11 (permalink)
Kiran.dks's Avatar
Yep....so it's the fault of your drive, not able to read disc well. Do some lens cleaning.
Kiran Kumar R
Old 20-09-2007, 12:57 AM   #12 (permalink)
digit i am thinking's Avatar
one ques. I found After some time(1 yr) DVD drives don't work properly they make sound while running DVD and don't detect disk.IS it because of dust on lens.
digit i am thinking is offline
Vanished Disk space! mario_pant Hardware Q&A 3 06-03-2006 09:22 PM
GRUB Vanished rajatheking Open Source 2 22-08-2005 09:21 PM
Multisession CD/Previous data vanished!!!!!!! linardni QnA (read only) 4 04-08-2005 11:20 PM
My Xp Search button Has vanished. praveenj QnA (read only) 3 15-02-2005 02:31 AM
fILE jUST vANISHED ! HELP vijaythefool QnA (read only) 1 09-02-2005 12:49 PM
- by tkin
