Old 16-09-2007, 08:32 PM   #1 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default GrandPerspective (For Mac)
GrandPerspective is a small utility application for Mac OS X that graphically shows the disk usage within a file system. It can help you to manage your disk, as you can easily spot which files and folders take up the most space. It uses a so called tree map for visualisation. Each file is shown as a rectangle with an area proportional to the file's size. Files in the same folder appear together, but their placement is otherwise arbitrary.
http://grandperspectiv.sourceforge.net/
WISH THIS WAS FOR WINDOWS TOO!!!
Life is as complicated as you say it is.
shady_inc is offline
Old 16-09-2007, 08:48 PM   #2 (permalink)
Default Re: GrandPerspective (For Mac)
Check out Sequoia view at http://w3.win.tue.nl/nl/onderzoek/on...oiaview//.html - it is a free Windows program that does pretty much the same... Actually, it is an old program and there are many more free alternatives these days...
Arun
sakumar79 is offline
Old 16-09-2007, 08:59 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
i think there is something similar ... and it was posted here long ago
http://beingmanan.com
iMav is offline
- by tkin
