Old 15-09-2007, 08:33 PM   #1 (permalink)
saurabh.sauron's Avatar
Default Visual Basic 2005 Query
I have made a program in Visual Basic 2005. I have used the VLC Media Player ActiveX Control to play media from my form. As my program is essentially a media player, I want to make my program run on computers that dont have VLC Player installed. Is that possible? If yes how?
pls help
thnx
PS: Is there any link regarding resources on using Windows Media Player in Visual Basic. I have embedded a control but still dont know how to use it.
thnx
saurabh.sauron is offline
Old 15-09-2007, 09:24 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Visual Basic 2005 Query
pls help
thnx
you have to register axvlc.dll and libvlc.dll through a setup project. This will be cone automatically when you create a setup for your project.
thnx
For playing a media file you have to use the URL property. Just assign a file to the WMP component like
AxWindowsMediaPlayer1.URL = "C:\test.avi"
Charan is online now
Old 16-09-2007, 05:44 PM   #3 (permalink)
how do i create an installer for my application? I have VB 2005 Express, and I dont think it allows creation of Setup and Deployment apps.
Old 16-09-2007, 05:51 PM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
use NSIS installer its free.
there are still many other. but not easy as this does
Gigacore is offline
Old 16-09-2007, 05:57 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Use installshield express or install creator..
Pathik is offline
Old 16-09-2007, 06:08 PM   #6 (permalink)
I managed to create an installer, but when i uninstall VLC, the application doesnt run. how do i do that?
Old 16-09-2007, 06:13 PM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
upload ur app and give the link here... let others see if its working or not
Gigacore is offline
Old 16-09-2007, 06:21 PM   #8 (permalink)
i have attached my program
Old 16-09-2007, 06:28 PM   #9 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Dude its working perfectly.Congrats.
BUGS:
1.full screen mode is not working while playing audio files.
2.problems playing video files(I tried .mpg)
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 16-09-2007, 06:33 PM   #10 (permalink)
without vlc installed?
Old 16-09-2007, 06:34 PM   #11 (permalink)
I have vlc installed.
Old 16-09-2007, 06:35 PM   #12 (permalink)
that is the problem. i want it to work on computers that dont have VLC installed.
Old 16-09-2007, 06:38 PM   #13 (permalink)
Dreamweaver
Gigacore's Avatar
@ Devil... see if it works after u uninstalled VLC...
Gigacore is offline
Old 16-09-2007, 08:59 PM   #14 (permalink)
18 Till I Die............
How will it work without VLC? Aren't you calling dll's from VLC? And what about codecs and stuff?
http://www.bash.org/?258908
mehulved is offline
Old 16-09-2007, 10:31 PM   #15 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yeah, unless you bundle whatever you use along, how would it play?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-09-2007, 01:19 AM   #16 (permalink)
Rubik's Uncle!!
Charan's Avatar
I see that dll's you have in that project are just wrappers. You need to add a new setup project to the solution. And then make it register through the properties. Once the setup is created you have to run this setup for the DLL's to get registered. Remember when working with COM you need to register the COM components through setup or using "Regsvr32" in a command prompt to register the component.
Old 17-09-2007, 02:51 PM   #17 (permalink)
I am using VB2005 Express. What do i do...it doesnt support setup appls. pls help.
Old 17-09-2007, 03:07 PM   #18 (permalink)
Rubik's Uncle!!
Charan's Avatar
I havent used other setup applications so cannot tell/check if they support registering COM. If you are just expreimenting then just use "regsvr32" to register the components and then run your application.
Old 18-09-2007, 08:57 AM   #19 (permalink)
i tried with third party software but it didnt work. i guess i have to try something else.
Old 18-09-2007, 09:35 AM   #20 (permalink)
you can use inno setup. Its a freeware and it does support registering COm while installation. Find it here http://www.jrsoftware.org/isinfo.php
[Mayank] is offline
Old 18-09-2007, 12:21 PM   #21 (permalink)
how do i add the scripting for the registration of COM components in Inno?
Old 18-09-2007, 01:13 PM   #22 (permalink)
ok here is an example
[Files]
Source: "C:\Documents and Settings\Administrator\Desktop\vb tech\vbfiles\MSWINSCK.OCX"; DestDir: "{sys}"; Flags: restartreplace sharedfile regserver
This will register the ocx while installation. You can play around with the flags at the end if you want. For more info refer to its documentation
[Mayank] is offline
Old 18-09-2007, 02:50 PM   #23 (permalink)
I dont have the VLC OCX file. Which control do I register now?
Old 18-09-2007, 06:16 PM   #24 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^^ VLC doesnot have a OCX file, it has the DLL file.
Old 18-09-2007, 07:54 PM   #25 (permalink)
so which files do i register during the installation? i cant seem to register libvlc.dll
Download Visual Basic 2005 express edition????? anmol004 Software Q&A 15 07-06-2007 01:55 AM
Visual Basic help! romeo_8693 QnA (read only) 18 17-02-2007 07:55 PM
Free MS SQL 2005 and Visual Studio 2005 from M$ rakeshishere Technology News 2 24-09-2006 03:24 PM
Visual Basic Query godsownman QnA (read only) 5 30-03-2006 04:10 PM
