Old 15-09-2007, 08:12 PM   #1 (permalink)
bajaj151's Avatar
Default Startup Error
Reboot and select proper boot device...comes when i start my pc....
then I press ctrl+alt+del....to restart ....then error disappears...
I checked my cables....whether they r loose or not....they r perfectly fine...
Whats the reason for this error ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 15-09-2007, 09:34 PM   #2 (permalink)
slugger's Avatar
Default Re: Startup Error
wat OS u usin?
wat recent changes did u make dat cud have caused dis problem?
post a screenshot if u can or post d complete message
check out ur event viewer to c wat is cusing d problem
slugger is offline
Old 15-09-2007, 10:15 PM   #3 (permalink)
bajaj151's Avatar
Originally Posted by slugger
wat OS u usin?
My OS: Window Vista Ultimate
No changes....fresh installation
Error during windows startup Hari_04415 Software Q&A 8 26-01-2009 01:18 PM
Window display fatal Error during startUp Kaushal Hiwarkar Software Q&A 2 13-05-2007 12:23 PM
Error Message on Windows Startup in XP sushantvirdi Software Q&A 24 25-01-2007 07:59 PM
serious startup error in windows xp sac_meer Software Q&A 2 13-11-2006 11:21 PM
error on startup vandit QnA (read only) 4 07-06-2005 09:31 PM
