Old 15-09-2007, 07:42 PM   #1 (permalink)
mad1231moody's Avatar
Default How to backup ??
Hey friends I have no idea as to how do i backup my windows drive and restore it as and when required ? Currently I have installed all the neccessary software that i require on the windows drive. Tell me how will I backup the windows drive on a DVD and how will I be able to restore if my windows goes Kaput ???
Please help me out as i reinstall every 2 months. And i am tired of installing everything again and again
mad1231moody is offline
Old 15-09-2007, 08:01 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: How to backup ??
Try Nortan GHOST--easy to use and fast.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 15-09-2007, 08:23 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Either that or Acronis True Image
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-09-2007, 10:41 PM   #4 (permalink)
The Frozen Nova
casanova's Avatar
Use Acronis True Image. It will give you very good results.
www.nerdweed.blogspot.com
casanova is offline
Old 16-09-2007, 11:11 AM   #5 (permalink)
at i need is to backup the windows directory and all the settings that will not account to more than 4Gb and hence will fit on a DVD
Old 16-09-2007, 11:47 AM   #6 (permalink)
Ever heard of splitted archives?
Old 16-09-2007, 12:09 PM   #7 (permalink)
Commander in Chief
Um, I don't think simply copying the files would work well. Its better to record the image of the drive and then place it as you wish, anytime.
Harsh J
www.harshj.com
Old 16-09-2007, 04:49 PM   #8 (permalink)
Nav11aug's Avatar
+1 for Acronis
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 17-09-2007, 04:16 PM   #9 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Norton GHOST ...... easy & best option .............
... W H O T ...
ax3 is offline
Old 17-09-2007, 05:35 PM   #10 (permalink)
Well don't give me the best one for backup.. I am ignorant of the process guys.
I have seen some of them have just made some 1Gb images and are able to restore system to full throttle. And I think that they use Ghost for the purpose
Backup Sms tanush_89 Mobiles and Tablets 3 08-08-2007 05:31 PM
SMS Backup, is it possible? Shasanka_Gogoi Mobiles and Tablets 12 13-04-2007 09:07 PM
Backup !!!!!!!!!!!!!!! tehnogeek Software Q&A 1 25-02-2007 01:39 PM
I want 5 Hrs or More thn tht...Backup.. hmmmmmmmmmmmmm QnA (read only) 9 28-08-2006 02:45 PM
registry backup means hd backup????? magnet QnA (read only) 3 01-04-2005 11:00 PM
