Old 14-09-2007, 11:29 PM   #1 (permalink)
Question Blue screen
With blue screen following message display:-
A Problem has been detected and windows has been Shut down to prevent damage to your computer
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is..........
Check to make.............
If problem continue,......
Technical information
***STOP: 0x000000D1 (0x00000034,0x00000002,0x0000000,0xF97F48F0)
***IdeChnDr.sys - Address F97F48F0 base at F97EF000, DateStamp 3d99eac3
Beginning dumpof physial Memory
Physical memory dump complete
Contact your system administrator or technical support group for further assistance.
OS: windows xp Pro.
Intel 850mv motherboard with intel P4 1.5 processor
Samsung DVD ROM etc.
Pl. show solution
Nandkishor Kale is offline
Old 14-09-2007, 11:40 PM   #2 (permalink)
slugger's Avatar
Default Re: Blue screen
if u usin Logitech Mouse den u may wan2 install d latest mouseware from their website
have u also istalled sum new hardware recently like a new Hard disk or sumthin? if so den it can aslo b d cause of d problem, unplug it and c if it solves ur problem
i can say this bcos u have poste d IDECHNDR.sys in ur error message
u may wan 2 uninstalld friver and den re-install it
slugger is offline
Old 14-09-2007, 11:48 PM   #3 (permalink)
Pee into the Wind...
shady_inc's Avatar
This may be caused if you installed some new hardware or sofware recently in a faulty manner.When does this error exactly occur.During bootup?? (my most likely guess).
Life is as complicated as you say it is.
shady_inc is offline
Old 16-09-2007, 01:41 AM   #4 (permalink)
Thanks for the suggestion. I will go for the latest driver of Logitech mouseware. The problem occurs during boot, but it came few days before during work. Meanwhile the frequency of error was incrised & at last I reinstalled the OS by another PC. I will discuss, if the error comes again. Thanks
OK
Last edited by Nandkishor Kale; 16-09-2007 at 01:41 AM. Reason: Automerged Doublepost
Old 17-09-2007, 06:01 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
just driver conflicts ........ install latest 1 if any particular new hardware installed ........
... W H O T ...
ax3 is offline
Old 18-09-2007, 12:40 PM   #6 (permalink)
Now I reinstalled the OS.
My PC has another problem from last two months. I am posting the new thred. pl. look it & suggest any solution.
Old 18-09-2007, 04:56 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
give the link of that thread
ravi_9793 is offline
Old 18-09-2007, 08:28 PM   #8 (permalink)
Distinguished Member
anandk's Avatar
ok i see you've reinstld ur os, but just for yr info:
STOP 0x0000000A or IRQL_NOT_LESS_OR_EQUAL
A kernel-mode process or driver attempted to access a memory location without authorization. This Stop error is typically caused by faulty or incompatible hardware or software. The name of the offending device driver often appears in the Stop error and can provide an important clue to solving the problem. If the error message points to a specific device or category of devices, try removing or replacing devices in that category. If this Stop error appears during Setup, suspect an incompatible driver, system service, virus scanner, or backup program. This KB314063 may show you the direction.
more at http://www.winvistaclub.com/t3.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Help me! Blue-screen george101 Hardware Q&A 6 29-10-2007 04:30 PM
blue screen rounit Software Q&A 5 15-05-2007 12:58 PM
Blue Screen :( soumya Software Q&A 11 13-02-2007 07:37 PM
Blue Screen Help naveen_reloaded QnA (read only) 5 25-11-2005 03:31 PM
blue screen sujeet2555 Software Q&A 4 15-11-2005 03:02 PM
