Old 14-09-2007, 09:41 PM   #1 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Lightbulb Logic Question - Number of combinations of bogies of a Train under a condition.
A train with n carriages labelled 1, 2, 3, . . . n, in that order, is standing on a railway
track. The railway track has a short siding that can accommodate upto two carriages.
As you move the train past the siding from left to right, you can do one of the following
at each step.
(i) Move a carriage from the left side to the right side directly.
(ii) Move one or two carriages into the siding, only if the siding is currently empty.
(iii) Move all the carriages out of siding to the right side.
Depending on the sequence of operations you perform, the carriages in the train may
be reordered. For instance, if you start with five carriages 1, 2, 3, 4, 5, you can reorder
this as 1, 4, 2, 3, 5 by keeping 4 in the siding, sending 2 and 3 to the right, then moving
4 out of the siding and finally moving 1 to the right. Similarly, you can generate the
order 1, 3, 4, 2, 5 by keeping 3, 4 in the siding when you move 2 to the right.
Note that you cannot add a carriage to the siding if it is not empty, even if there is only
one carriage currently in the siding. Similarly, if there are two carriages in the siding,
you cannot remove only one of them and move it to the right—you must remove both.
Thus, for example, you cannot generate the order 3, 1, 4, 2, 5. Since 2 is adjacent to 5,
3, 4 must have gone into the siding together, but they have come out separated by 1,
which is not permitted.
Overall, if one tries out all possible ways of using the siding while moving a train with
five carriages, there are 24 different ways in which the carriages can be reordered.
How many different reorderings can you generate if you have a train with:
(a) 8 carriages
(b) 9 carriages
(c) 10 carriages
PS: I really need a solution to this question , i'm preparing for Computing lympiads n i can't solve this particular question n can't find any source on how to solve it .
Also if you can recomend me any books to learn/practice these type of Problem's itll be very helpful.
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 15-09-2007, 01:51 AM   #2 (permalink)
Nav11aug's Avatar
Default Re: Logic Question - Number of combinations of bogies of a Train under a condition.
Listen .. work out the combinatorics for yourself but the solution is ... for n carriages , the no of reorderings that can be produced is (n-1)!
So,
(a)5040
(b)40320
(c)362880
I dunno what kind of book u wnat...only for combinatorics or learning 'intelligent' math
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
cpu motherboard combinations direfulsky CPU / Motherboards 2 28-07-2007 11:09 PM
How to identify Local sms number and National sms number? casual_gamer Mobiles and Tablets 2 04-12-2005 02:31 PM
MS train simulator d QnA (read only) 2 28-10-2005 12:46 AM
BVE Train simulator ferrarif50 Gamerz 2 26-09-2005 09:15 AM
RAID: Permutation & combinations??? tarun_34 QnA (read only) 6 24-02-2005 04:37 AM
