Old 14-09-2007, 09:06 AM   #1 (permalink)
kantiman's Avatar
Default changing shutdown to hibernet
How can I change the function of the shutdown to make the pc go in hibernet. I mean when i click on the shutdown button the pc should hibernet. I dont want the hibernet button to show up in the shutdown dialog box.
kantiman is offline
Old 14-09-2007, 01:27 PM   #2 (permalink)
slugger's Avatar
Default Re: changing shutdown to hibernet
then how will you shutdown the computer?
slugger is offline
Old 14-09-2007, 06:35 PM   #3 (permalink)
kantiman's Avatar
I dont want to shutdown.
kantiman is offline
Old 15-09-2007, 01:25 AM   #4 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Its not good to never use shutdown. BTW only a programmer can try that what you want. Hibernating frequently will slow down system in long run. Shutdown atleast twice or thrice a week.
navjotjsingh is offline
Old 15-09-2007, 01:27 AM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Edit "msgina.dll" file in Resource Hacker and remove the shutdown button.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-09-2007, 01:30 AM   #6 (permalink)
slugger's Avatar
arrrre nahi yaar !!!
dis guy wants 2 re-assign d shutdown key to hibernate function
people wan2 do strange things with their computers
slugger is offline
Old 15-09-2007, 01:31 AM   #7 (permalink)
Nav11aug's Avatar
Control Panel>Power Options >Advanced
In the bottom pane change "When I press the ....." to "Hibernate" frm teh drop down list
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 16-09-2007, 05:34 PM   #8 (permalink)
kantiman's Avatar
I do shutdown the pc every night. But I keep the PC on the whole day and my friends turn it off which I dont want. I want it to go into hibernet. I ve kept the option of shutting down when I press the power key, so that when I want to shut down i just press the power key. and when my friends do it from windows it should hibernate.
kantiman is offline
Changing IST from +5.30 to +6.00 ╬Switch╬ Chit-Chat 6 03-09-2007 11:08 PM
changing name vineeth.gk QnA (read only) 5 28-07-2007 12:22 AM
changing ip!!! prinz QnA (read only) 6 03-07-2007 12:48 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
"improper shutdown" msg on proper shutdown mvishnu QnA (read only) 2 26-02-2006 06:50 PM
