Re: How can i get computer output on tv instead of my monitor. I dont have tv tuner card
computer output on tv is rather very simple all u need is a display card which has a video out ... get urself the cable u might even get it bundled with ur display card ... connect it and switch to video on ur tv .... it shoudl be there ... but the resolution will be the 1 that ur tv supports ... start with 800x600 and then increase to chk the highest reso supported
http://beingmanan.com
