If you're getting snowing effects and blurred text, then that means that the image size is too big for the presentation and PowerPoint would have scaled it down to fit it. This will definitely lead to a horrible blurring. What you need to do is save the file with a smaller image size and a resolution from inside CorelDraw and then use that image in PPT. Experiment with different sizes of the picture, but do not resize the picture within PPT, that will definitely distort the picture.
Playing FEAR XP/LSW2
