Old 12-09-2007, 06:54 AM   #1 (permalink)
newbee
Default pc restarts.. what is the reason?
my intel d101gcc mobo "features guide" says that it supports ddr400\300mhz rams.So ddr means ddr1 right? and i feel every apps including games and winamp closes with MS error report sceen appearing.my pc restarts itself sometimes.i thought tht it may be due to ram it is 2yr old one and mobo is just bought on last november.its very dispointing when pc restarts convertxtoDVD sw converts videos to DVD 87% pls advice me...
Aone is offline
Old 12-09-2007, 09:58 AM   #2 (permalink)
Default Re: pc restarts.. what is the reason?
THe 1st advice is to check ur power supply,
2nd check if ur system is not over heating.
ranjan2001 is offline
Old 12-09-2007, 11:35 AM   #3 (permalink)
ayush_chh's Avatar
ur mobo is new so there is no chance of dusty slot but its better if u check....
has this problem started just after u bought the new mobo??
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 12-09-2007, 05:21 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
just open ur cabinet, its heating problem ........
check ur FANS ...... clean them up, if dust prevents it from rotating ......
try switching RAM from ur frds pc if same frq .....
or TRY software used 2 check hardware speed, temp .......
... W H O T ...
ax3 is offline
Old 12-09-2007, 05:30 PM   #5 (permalink)
i think it is the problem of heating.otherwise check the power supply.
thecreativeboy is offline
Old 12-09-2007, 07:47 PM   #6 (permalink)
Maximum Fame
quadroplex780's Avatar
Newer mother boards have protection for overheating and so do processors your problem is surely releated to ram module or dimm Just replace it with a new good quality ram module(512MB 400Mhz)And see how it works for u.
quadroplex780 is offline
Old 13-09-2007, 08:17 PM   #7 (permalink)
newbee
thanx guys for helping.i hope it is ram problem i'm changing it.it was 512ddr333mhz.my cpu sounds loudly like a highspeed fan when ram usage is heavy like cd burning or playing games or coverting videos etc cpu temp as in bios is 60 to 66 celsius.how to check temp in normal stage?
Aone is offline
Old 14-09-2007, 08:00 AM   #8 (permalink)
Download speedfan for temp reading from here http://www.almico.com/speedfan.php
IE6 Closing For Apparantly No Reason karnivore Software Q&A 18 14-07-2007 11:12 PM
URGENT!!Computer restarts without reason! max_demon Hardware Q&A 2 22-06-2007 12:00 AM
ONe more reason to buy 6630 champ_rock Buying Advice 13 03-11-2005 12:36 PM
