Old 12-09-2007, 12:14 AM   #1 (permalink)
jyoti.mallick02's Avatar
Default how to change the dvd-ram drive icon????
i tried iconpackager,tuneup utilites but nothing happens pls give me a solution
i post the image how my drives r change but the cd drives r not changeing
**i did not know where to post so posted here !!!
jyoti.mallick02 is offline
Old 12-09-2007, 01:26 AM   #2 (permalink)
shashank4u's Avatar
Default Re: how to change the dvd-ram drive icon????
These icons are not changing becoz they took the shape of the icon or image in the cd/dvd you insert in your dvd drive...Its depends on the ico file present in cd/dvd
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 12-09-2007, 01:37 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open "Shell32.dll" file in Resource Hacker and manually replace the icon with your desired one. To know more about Resource Hacker:
TUTORIAL: All About Resource Hacker! A Brief Tutorial
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 12-09-2007, 01:52 AM   #4 (permalink)
shashank4u's Avatar
I was thinking that Vishal gupta can answer this question and there u are ..
change Documents icon jampatana Software Q&A 1 23-10-2006 10:38 AM
How to change an icon of an .exe file??? go4saket QnA (read only) 4 09-10-2005 08:02 PM
How to change Icon Font colour ? QwertyManiac QnA (read only) 5 14-09-2005 05:15 PM
