11-09-2007, 10:01 PM
CD Drive door is automatically coming out...
Dear Friend,
I've noticed that my Combo Drive door is coming out automatically. Even if I close it, it comes out immediately. I have to close it 10 or 15 times to stop it temperorily. Is there any solution for this?
Thanks in advance.....
11-09-2007, 10:19 PM
Pee into the Wind...
Re: CD Drive door is automatically coming out...
Do you put in the CD correctly???
Try updating the firmware,check whether all connections to CD drive are secure.
Life is as complicated as you say it is.
11-09-2007, 11:35 PM
Rebooting
@alanpaladka
Tell me thats not a SAMSUNG drive  if yes, then  its a common problem... !!!
rebooting
ChotoCheeta.com
14-09-2007, 12:28 AM
Yes. Thats SAMSUNG Drive. Got 3 years ago from a DIGIT OFFER
14-09-2007, 12:31 AM
Wire muncher!
time to replace it wid a non samsung drive! there's a long history of this problem wid samsung drives.
14-09-2007, 12:34 AM
GUNNING DOWN TEAMS
please urgently go to BAZAAR section...put it on sale and buy a new NON-SAMSUNG one
14-09-2007, 12:35 AM
Wire muncher!
you think ppl will buy it if he puts it for sale in the bazaar section of THIS forum??!!
14-09-2007, 12:44 AM
Google Bot
Haha.. Btw just get a new 1.. Just 1.6k these days.. Get a sony dru 835a
14-09-2007, 03:49 PM
i was also face the same one..... but still im using the same drive without any problem...... since 1 and half year.........
one of my frnd had said it was due to virus..... i used a good virus removal and solved that problem.... try it i dont know it will help u or not......
just remove the connection to use ur pc without any trouble......
14-09-2007, 04:24 PM
Dreamweaver
He he he.... this is a cool problem.... i had this prob.... i thought it was a virus... but after searching through the net i replaced it with SONY
14-09-2007, 04:45 PM
Cool as a CUCUMBAR ! ! !
ya mine SAMSUNG drive has same problem & i just BANG or push it .....
& being doing this 4 a long time ........
... W H O T ...
14-09-2007, 05:09 PM
M$™ Certified Spammer
try firmware update
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
14-09-2007, 05:10 PM
Dreamweaver
New Samsung drives.... with some TM like OctoEdge.... is OK... i've a COMBO its... rocks!!
14-09-2007, 05:12 PM
i have octoedge too it doesent have that problem though
14-09-2007, 06:19 PM
I was also having a similar problem with a samsung drive .I opened it and cleaned all it components and it was allcorrect again and also don't forget to apply white grease in right areas.
14-09-2007, 08:10 PM
^^^Grease???In CD drives??please elaborate...
Originally Posted by entrana
try firmware update
Yup,You should do a firmware update before buying a new one.
14-09-2007, 08:57 PM
Try keeping a cd in the drive at all times.
14-09-2007, 09:13 PM
left this forum longback
toshiba-samsung octoedge dvd-writer FTW!!!
15-09-2007, 06:53 PM
#19 (permalink)
I'm very much sure that its not because of Virus problem. I'll try the firmware update.
15-09-2007, 07:06 PM
#20 (permalink)
Even my digit samsung has the same problem
Never worry dude
15-09-2007, 10:20 PM
#21 (permalink)
Beware of the innocent
oh, that is actually a feature in samsung drives. Keeps your system cool by providing more ventilation.
Life is too short. Have fun.
15-09-2007, 10:51 PM
#22 (permalink)
^is it a Joke?Namba mudiyella!iisappa kaappathungA!
toshiba-samsung octoedge drives works fine talaiva!
16-09-2007, 05:37 PM
#23 (permalink)
joke thaan pa. kavalai padathey. unnode bhakkiyam nallathayirukku samsung drive sariya velay seyyuthunna. Evvalavu palasu athu?
16-09-2007, 06:05 PM
#24 (permalink)
^puthooose ayya!new octoedge dvd writer SH-S182F.times are changing alas!
16-09-2007, 10:04 PM
#25 (permalink)
oru varusham kaluchi parpoma?
16-09-2007, 10:23 PM
#26 (permalink)
^kandippaa!
17-09-2007, 05:19 PM
#27 (permalink)
Ho..ho..ho...b4 tryin all those do urself a favor and check whether the area around the disc tray is clean and free from dust nd grime...if not clean it and if possible open up the drive and clean the rollers and guides of the tray...I think this prob is because some dirt is preventing the drive tray from closing correctly and hence keeps popping out often.!
18-09-2007, 07:15 PM
#28 (permalink)
I've updated the firmware. But same problem still exists!
Search this Thread |
