Old 12-03-2005, 11:18 AM   #1 (permalink)
why need title?
bharathbala2003's Avatar
Default how 2 copy?
well i rem once i had a zip file of 6mb.. and i used 5 floppy's to copy it.. so when i had to extract i had to insert the first floppy and click on extract.. and it finishes a certain amt n then asks for the second floppy.. n like that. but i forgot how i copired it 2 floppy.. (was bout 5 yrs back) now am tryin 2 copy a zip file of 4.2 mb into 3 floppys but am not able to.. does any1 here know how 2 do it? plz help me.. its a important s/w.. the respected person to recieve the floppy doesn have net so cant send in mail.. so plz help
bharathbala2003 is offline
Old 12-03-2005, 11:25 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
Use WinRAR and split it into required number of parts of specified size using it
in ur case abt 1024 Kb in 3-4 parts as ur case is
Sourabh is offline
Old 12-03-2005, 11:27 AM   #3 (permalink)
ramprasad's Avatar
Hi
Insert the empty floppy intothe drive and rt click on the file u want to zip. Choose "Add to Zip" and Destination name text box enter "A:\Nameofthezipfile.zip" and automatic disk spanning will be enabled.....
Regards,
Ramprasad
ramprasad is offline
Old 12-03-2005, 11:37 AM   #4 (permalink)
tuxfan's Avatar
I have a small software called InfoSplit 2. That splits any file of any size into as many parts as you want. Tried it successfully some time back and copied 4 full marriage VCDs from one machine to another using a memory card
Tell me if you want it.
tuxfan is offline
Old 12-03-2005, 11:44 AM   #5 (permalink)
why need title?
@sourabh i dint know how 2 split it as u said..
@ram thnx.. worked out..
[edited]
@ram it copied.. but when i tried to open it its not openin..
says
error [A:\spybot13.zip]: unrecoverable zip file read error
Old 12-03-2005, 11:45 AM   #6 (permalink)
why need title?
@tuxfan.. sure id like that.. can u send it to bharathbala2003@gmail.com
Old 12-03-2005, 06:13 PM   #7 (permalink)
swatkat's Avatar
there's a software called Dariolius, which is a very good file splitter. it has a lot of options, like "fit to floppy", "split into equal parts" etc. It makes a small EXE file, when u run it, it will automatically join the split files.
http://www.kanastacorp.com/dariolius.html
http://swatrant.blogspot.com/
swatkat is offline
Old 12-03-2005, 06:46 PM   #8 (permalink)
why need title?
@swat i downloaded that.. but then this is wat came..
run time error 429
active x component cannot create object
Old 12-03-2005, 06:57 PM   #9 (permalink)
hack expert's Avatar
file splittin utilities are the best info split is one of the best well also the other user does not require the software if u use info split he has to recombine usint a .bat file
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 12-03-2005, 09:33 PM   #10 (permalink)
Download and try splitter.
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 12-03-2005, 10:15 PM   #11 (permalink)
why need title?
@inder thnx.. it worked out fine.. finally...
Old 12-03-2005, 10:18 PM   #12 (permalink)
You are welcome!
indrajit is offline
Old 12-03-2005, 10:47 PM   #13 (permalink)
Just google it.
There are loads of applications for file splitting.
Also some shell extentions are available for doing it.
amitsaudy is offline
Old 13-03-2005, 11:01 AM   #14 (permalink)
ramprasad's Avatar
Hi
I used to do the way I said very often.... And why dont u try this file splitter. It is a freeware.... http://www.dekabyte.com
Regards
Ramprasad
Old 13-03-2005, 11:37 AM   #15 (permalink)
vysakh's Avatar
there is a tool split it
it came once with digit.
or you can google it. It is very simple, easy to use and has some good features too
Incompatible message format
vysakh is offline
Old 13-03-2005, 01:58 PM   #16 (permalink)
why need title?
thnx for the info guys.. already done it with the tool inder gave
Old 13-03-2005, 03:21 PM   #17 (permalink)
Ignorance is BLISS !!
there r lots of softwares for ur needs at
www.download.com
rajkumar_personal is offline
Old 14-03-2005, 04:07 PM   #18 (permalink)
tuxfan's Avatar
I didn't see this post and have sent you the file splitter InfoSplit 2 by email.
tuxfan is offline
Old 14-03-2005, 04:23 PM   #19 (permalink)
@bharathbala2003
what u did @ram's method was correct,but before using this method ,check if all the floppies being used dont have bad sectors (use scandisk) This was what happened in ur case.this is a very unsafe method since ,even if a single floppy went bad after u zipped ur files, the whole data becomes unrecoverable.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 14-03-2005, 05:33 PM   #20 (permalink)
why need title?
@tux no probs... thnx for the file
@blacklight i did a scandisk.. no errors m8.. anyways as i said above it already worked out using the splitter..
Old 14-03-2005, 06:45 PM   #21 (permalink)
use g split simple and no need to have that software on the pc u are trying to join back just run the exe.its free
vijaythefool is offline
Old 14-03-2005, 06:58 PM   #22 (permalink)
why need title?
@tuxfan i jus chkd my gmail.. i haven recieved any file from u yet try sendin it again.. my id is.. bharathbala2003@gmail.com
Old 15-03-2005, 03:00 AM   #23 (permalink)
parthbarot's Avatar
many splitters r there...u can also use winrar or winzip for file spliting ...
regards
www.techlads.com
Paarth.
parthbarot is offline
Old 15-03-2005, 11:21 AM   #24 (permalink)
tuxfan's Avatar
Patience man, keep patience It will reach you in some time. I have sent it to you thru my softhome account and it takes a little while at times.
tuxfan is offline
