Old 12-03-2005, 11:18 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Photoshop help ! ! !
have created psd files & saved them also ...
bt after saving & closing them ...
next time when i open them, history has vanished ...
can u save history along with its respective psd file for use in a later editing session ???
ax3 is offline
Old 13-03-2005, 01:31 AM   #2 (permalink)
sms_solver's Avatar
i don't think it is possible.
Give one good reason to save the history along with the file
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 13-03-2005, 11:39 AM   #3 (permalink)
what u said is impossble . either u just saved the file as psd without using any tools or need to bring up the history from winows menu..
vijaythefool is offline
Old 13-03-2005, 12:45 PM   #4 (permalink)
NikhilVerma's Avatar
You can save the history in Photoshop...
Just goto Edit-- Preferences -- general...
And at the very bottom there is a option of saving history in a text file...
NikhilVerma is offline
Old 14-03-2005, 02:46 PM   #5 (permalink)
Thx Nikhil verma never used that option before , got to see it
Old 18-03-2005, 12:10 PM   #6 (permalink)
ax3
ax3's Avatar
cannot find this option ...
i use version 7 ...
... W H O T ...
ax3 is offline
Old 18-03-2005, 01:30 PM   #7 (permalink)
good tweak
Lovedeep Wadhwa
cheetah is offline
Old 18-03-2005, 05:48 PM   #8 (permalink)
i use version 7 ...
That's what it is... You can also save the history in the metatags of the file you are saving...
It doesn't bring the history back on te pallete but you will remember what you did ...
Old 21-03-2005, 11:31 AM   #9 (permalink)
ax3
ax3's Avatar
hey ...
nikhil ... where is the above option u mention ???
cannot find it ... i use version 7 ...
... W H O T ...
ax3 is offline
Old 21-03-2005, 08:07 PM   #10 (permalink)
I have version 8 (CS) maybe that's why..
