Old 10-09-2007, 04:11 AM   #1 (permalink)
On the net
arnab2kool's Avatar
Unhappy Where I can get this script? Can anybody help please?
Hello,
I need a script for a calender. If somebody has visited www.makemytrip.com then you will see a form for booking flights. When you click on the Departure Field or its calender icon nearby, the calender appears and you can scroll thru the months and can select it, and after selection the date, month and year appears on the field provided. Can anybody tell me where I can get this script? Please help me. Its urgent.
Thank you.
YOUTHS are not USELESS
YOUTHS are USED LESS
CORE 2 DUO USER
arnab2kool is offline
Old 10-09-2007, 01:34 PM   #2 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Default Re: Where I can get this script? Can anybody help please?
try this & this
koolbluez is offline
Old 10-09-2007, 07:26 PM   #3 (permalink)
piyush gupta's Avatar
great links superman
piyush gupta is offline
Old 11-09-2007, 02:16 AM   #4 (permalink)
On the net
arnab2kool's Avatar
Red face Re: Where I can get this script? Can anybody help please?
Originally Posted by koolbluez
try this & this
Thanks Koolbluez. You saved me. Keep up the good work.
Thank you.
CORE 2 DUO USER
VBA script satyamy QnA (read only) 6 25-04-2007 01:45 PM
My PHP Script cheetah QnA (read only) 13 14-09-2005 12:19 AM
CGI script help sridhar8310 QnA (read only) 1 09-01-2005 09:02 PM
