Old 09-09-2007, 09:46 PM   #1 (permalink)
ajaybc's Avatar
Question Is use of inverter harmful to computer?
One of the mechanics who came to repair my blown up SMPS a few weeks ago said that connecting computer to an inverter is very harmful and this had caused my SMPS.Friends is it true??????Iam really confused.
ajaybc is online now
Old 09-09-2007, 09:54 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Is use of inverter harmful to computer?
if you have good UPS between them (Inverter and Computer) then no, its not harm full...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-09-2007, 10:05 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Yep. I used inverter backup for many years in my desktop and now using it in my laptop.
No harm.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-09-2007, 11:31 PM   #4 (permalink)
that's a myth..
I use UPS + Inverter combo.
UPS takes care of the long switch over times of Inverter.
No problems with SMPS.
I wonder, the PC guy said this. 'Coz mostly the inverter suppliers say this. Many of them will give u 600VA or 800VA Local made Inverters which are just don't take stated LOAD.
So to keep their business clean the spread such myths...
ashnik is offline
Old 10-09-2007, 05:39 PM   #5 (permalink)
The Frozen Nova
casanova's Avatar
You can say it this way in terms of safety from electricity fluctuations:
UPS>Inverter>Booster>Stabiliser>Direct power supply.
PS: Booster will boost your voltage to 230 if it falls below even for longer duration.
www.nerdweed.blogspot.com
casanova is offline
Old 10-09-2007, 08:24 PM   #6 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
AFAIK u should not connect your PC directly to your invertor .
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 10-09-2007, 11:32 PM   #7 (permalink)
The Frozen Nova
casanova's Avatar
Ok, use a spike guard in between.
casanova is offline
Old 10-09-2007, 11:53 PM   #8 (permalink)
Dear all,
I think it is partially correct, because most inverters produce square waves of electricity. (first of all I don't know your inverter brand and its specifications) the local power is completely sine wave. All electronic devices designed for using sine wave. So there is a chance to damage the inverter to some highly sensitive devices. for example with some inverters we can hear a humming sound with fans.
check this link http://en.wikipedia.org/wiki/Inverter_%28electrical%29
thanks
shemi4444 is offline
Old 11-09-2007, 10:03 AM   #9 (permalink)
Sorry to say, But most of the Inverters I have seen are Sine Wave..
ashnik is offline
max. no of devices harmful?? karthik316_1999 QnA (read only) 2 17-07-2006 06:57 PM
Are they harmful for the system? hluachawngthu QnA (read only) 5 29-04-2006 07:56 AM
inverter v/s UPS rajesh_nk22 QnA (read only) 12 23-02-2006 11:37 PM
Aren't these harmful? The Incredible QnA (read only) 3 04-06-2005 10:40 PM
