09-09-2007, 04:51 PM
Any way
Hi Guys,
Windows XP Home Edition. Internet Explorer-7. When I am online, I would like to copy the necessary website pages on a clipboard and save them all in a file or folder or pen drive lastly. Is there any possibility, if not, any other ways for the purpose?
When I view some websites, the tool bar, I mean, File, Edit, View, etc, not visible and so I am unable to go either back or forward using the keys on the top of Tool Bar. Is there any way or any shortcut keys that will do best for my purpose? Your advice and suggestion?
09-09-2007, 05:21 PM
D i s t i n c t l y Ahead
Re: Any way
[QUOTE=kumarn_2004]Hi Guys,
press F11 nd the tool bar will become visible  after that u will be able to
save Web pages or copy the contents
09-09-2007, 08:08 PM
Re: Any way
[QUOTE=saurabh kakkar]
Originally Posted by kumarn_2004
Hi Guys,
Hi saurabh kakkar,
I did as you say but not visible. So, I am unable to go back and forward.
Reason: Automerged Doublepost
09-09-2007, 08:16 PM
Microsoft MVP
Re: Any way
Press <Alt>+Left Arrow key to go Back and <Alt>+Right Arrow key to go Forward.
11-09-2007, 06:20 PM
Re: Any way
Windows XP Home Edition. Internet Explorer-7. When I am online, I would like to copy only the necessary website pages on a clipboard and save them all in a file or folder or pen drive lastly. Is there any possibility, if not, any other ways for the purpose?
Hi Guys,
I am waiting for your kind reply.
11-09-2007, 06:49 PM
Re: Any way
This shouldn't happen.Any way, Just press Ctrl+A to select all the contents and then Ctrl+C to copy them,then create a webpage (in Frontpage or MS-Word) and paste them in it.But the pictures won't be copied this way.
12-09-2007, 02:36 PM
The Researcher
Re: Any way
click file>save as and give any suitable name.
15-09-2007, 03:57 PM
Re: Any way
Kumaran said that no option such as File, Edit appears.Read the post carefully first.I'm not criticising,just advising
15-09-2007, 10:54 PM
I am Optimus Prime
Re: Any way
he didn't said that both problems occur simulataneously.
16-09-2007, 08:46 PM
Re: Any way
Didn't got what you mean....Please explain.
16-09-2007, 08:54 PM
I am Optimus Prime
Re: Any way
he didn't say that file edit menus disappear when he wants to save the file. That I meant.
17-09-2007, 04:39 PM
Re: Any way
Originally Posted by Chetan1991
Hi Guys,
Your are correct. I mean that when I open some,not all, webpages online, it automatically disappeared.
Search this Thread |
