Old 09-09-2007, 01:59 AM   #1 (permalink)
vavinashraju's Avatar
Red face find missing files and folders :isobuster
when i m burning some .avi files on to the dvd using nero burning rom it is showing that it is burning completely........but after the process is finished when i check it ....it shows the disk as empty
when i use isobuster it shows a single file of the full size written as track 01 and asks me to find missing files and folders
then i tried to burn it again but i got the same result is there any way i can extract those files........please help
"The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila."
vavinashraju is offline
Old 11-09-2007, 01:07 PM   #2 (permalink)
s,b+..u cn..
nikhil ramteke's Avatar
Default Re: find missing files and folders :isobuster
there is hirarchical views try to explorer it...
u may get those pre-written files...
nikhil ramteke is offline
folders converted into files (16k) bydemandchd QnA (read only) 14 15-05-2009 07:17 PM
"Show hidden files and folders" button is missing Pragadheesh QnA (read only) 6 19-08-2007 06:12 AM
How to hide files and folders??? go4saket QnA (read only) 25 16-10-2005 11:11 AM
Can't open files/ folders. techpro_bunty QnA (read only) 2 11-01-2005 11:40 PM
