Old 08-09-2007, 04:05 PM   #1 (permalink)
pritish_kul2's Avatar
Default Contra not running
Guys,
It's giving the message '3D Hardware could not be initialized' and when i deselected 3D hardware , then it's giving this message 'Your computer does not have DirectDraw hardware'
pritish_kul2 is offline
Old 08-09-2007, 05:05 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Contra not running
Which Emulator are you using?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-09-2007, 08:12 PM   #3 (permalink)
slugger's Avatar
ur DirectDraw Acceleration is probably disabled
my suggestion
Start->Run
type in dxdiag
in d window dat opens select d display tab
in der u will find a section called DirectX Feature
there u can enable d disabled features
and since u r @ it, might as well re-install DX using d latest redistributable and latest Grafix drivers
PS: Assumed dat ur grafix card supports DirectDraw Acceleration
slugger is offline
Old 12-09-2007, 02:57 PM   #4 (permalink)
nahi all are disabled and there is no option of enbling them
Old 12-09-2007, 04:36 PM   #5 (permalink)
slugger's Avatar
dunno if it is bcos of this, but probably Hardware Acceleration is not set to maximum
2 check it out
Right click on d Desktop->Properties->Settings->Advanced->Troubleshoot->Hardware Acceleration
slide it to Full and c if it solves ur problem
den go back to dxdiag and enable them if needed
slugger is offline
Old 12-09-2007, 06:01 PM   #6 (permalink)
nopes. it says not available
Old 12-09-2007, 08:07 PM   #7 (permalink)
slugger's Avatar
wat GPU r u usin?
slugger is offline
Old 13-09-2007, 03:07 PM   #8 (permalink)
dn know
Old 13-09-2007, 04:48 PM   #9 (permalink)
slugger's Avatar
wat grafix card u usin?
did u try re-installin DX?
slugger is offline
Old 15-09-2007, 07:58 AM   #10 (permalink)
no
tried tht too
Last edited by pritish_kul2; 15-09-2007 at 07:58 AM. Reason: Automerged Doublepost
Old 15-09-2007, 09:05 AM   #11 (permalink)
slugger's Avatar
how old is your graphics card
maybe they dont support these features
slugger is offline
Does anyone over here know about old game Contra chandansomani Gamerz 17 21-01-2007 06:19 PM
Contra / Mario / PacMan pickster Gamerz 8 19-03-2006 10:51 AM
Contra in 12 mins!! Febians Gamerz 4 07-12-2005 03:28 PM
dvd not running sujeet2555 QnA (read only) 3 26-07-2005 10:09 PM
What are we Running After ? vswizard QnA (read only) 15 10-05-2004 10:17 PM
