08-09-2007, 10:29 AM
run 24 hrs a day Lappy OR Desktop
I have a IBM Laptop g41, should I keep that running for 8 hrs at night or my desktop which has a 400 watt PSU and a crt monitor
My main concern is the life of the pcs and energy conservation.
We must accept finite dissapointment. But we must never loose infinite hope.
08-09-2007, 10:33 AM
Google Bot
Re: run 24 hrs a day Lappy OR Desktop
The PC..
08-09-2007, 11:05 AM
Originally Posted by pathiks
The PC..
don't you think laptop will conserve a lot of power
08-09-2007, 11:22 AM
Rebooting
Laptops can do 24/7 too... just make sure u opt for a 3 yrs extended hardware warrenty
rebooting
ChotoCheeta.com
08-09-2007, 11:30 AM
Wire muncher!
^^^ nothing happens man... don't worry! for extended period it better if u use the laptop as that saves a substantial amount of power.
08-09-2007, 11:35 AM
thanx for your reply.
i have about harddisk need a break of 30 minutes in a whole day. is that correct
08-09-2007, 11:38 AM
Rebooting
Cant say what would happen if you dont give a HDD break, as all my frnds who owns Lappy, Lenevo / HP / Dell / Acer many runs 24/7, but all have 3 yrs warrenty... but as infra_red_dude said, still they have not faced any problem..
Personally, i have run 24x7 not actuall as for Power failure in every 2/3 days I needed to have a 10 or 20 mins break..
rebooting
ChotoCheeta.com
08-09-2007, 11:40 AM
Wire muncher!
i cudn't understand ur Q. are you trying to say that the hdd needs to be powered down for at least 30mins in a day, or something?
if thats ur Q, then the answer is NO as there is no written documentation by even the hdd manufacturers which says so. hdds of today are robust. so dun worry. again, as to when an hdd fails.. nobody can predict that. mebbe due to some malfunction in the internal electronics or shocks or surges they may go bad. so there isn't something which can say when the hdd will go bad for sure. but the average normal ageing process takes about 6-7 years to kill the hdd. but, i haf a 9 year old 4.3gb still going strong
08-09-2007, 11:49 AM
thanx a lot
08-09-2007, 12:04 PM
Šupər♂ - 超人
i use my new 95k 17" C2D lappy... from 4aft to 2 @ night...making that 10hrs.... straight.... will it cause heartburns l8r... seriously speaking...
08-09-2007, 12:07 PM
Commander in Chief
Nopes, not if its not heating up a lot, of course.
Harsh J
www.harshj.com
08-09-2007, 12:19 PM
Google Bot
If u use a lappy that much the battery ll surely degrade over time..
08-09-2007, 12:24 PM
Wire muncher!
ok now this is something really to be discussed. thanks for bringing up the point, pathik.
if you are running the lappy continuously on AC power for extended periods then UNPLUG the battery for its longer life. discharge it upto mebbe 40-50% and store in a cool dry place. my uncle has a dead battery in his lappy coz of this practice of keepin it in the lappy and using AC all the while.
08-09-2007, 01:21 PM
Hmm I think I should remove the batt from my lappy as well, It has last two runs of 49.5 and 47.5 hours, no standby no hibernation only LCD went off but the thing is that I use it coz I download stuff and in case of power outage I do nt have to bother until 2-3 hours. ie until battery runs
08-09-2007, 02:20 PM
Wire muncher!
yes, thats the only advantage! but if u haf a ups, by chance, in ur place even that problem is solved. even the ups for a desktop will do jus in case of a small power outage. u can connect both of them simultaneously.
08-09-2007, 02:57 PM
mera kutch nahi ho sakta
r u sure abt this? and does this apply to li-ion batteries
jin files ka koi server nahi hota unka bittorrent hota hai
08-09-2007, 04:03 PM
Another Brick in the Wall
I run my Inspiron 6400 on an average for 12-15 hours a day. Sometimes it 12 hours or more on a stretch and then after some time even more for 1-2 hours.
I'm using like this for almost 7 months now and nothing had happened till now. The Battery is also in top condition. Yes, after sometime the Battery might worn out, and this is normal.
So you don't have to worry about your lappy running long hours. It's built to run like that.
chesss -
It's true. I never keep my lappy for AC power unless it's needed. I charge the battery 100% and then unplug the power till it goes less than 10%. I keep doing this. But ppl say the newer batteries to designed for 500 charge cycles. After that the battery goes kaput.
08-09-2007, 05:31 PM
But that beats the purpose of buying a laptop! Download without electricity, since the modem goes on inverter. immidiately
08-09-2007, 06:54 PM
#19 (permalink)
how much amount of current does a laptop take as compared to desktop of similar configuration
how much difference is there
08-09-2007, 07:55 PM
#20 (permalink)
Console Junkie
One question. I have an HP nx6110. I have been using it 24X7 for about 7 months now. (Before that is was about 8 hours a day). I switch it off periodically, maybe once in 12-20 days.
Now, it does not have any alternate power in except for the battery. What to do? I cannot remove the battery and use the laptop.
One more thing. You said that it does not affect the H/W, if laptop runs long. I have had countless H/W problems. But ofcourse, most of them were before these 7 months of 24X7 running.
Any ideas?
--- Console Junkie
08-09-2007, 10:48 PM
#21 (permalink)
Wire muncher!
yes sir, i'm talking about a scenario when you hardly use the battery. ie thruout the week if the laptop's powered on AC and out of that u run the laptop on the battery for a few minutes then this holds true. u may not notice an immediate detrimental effect on the battery. but it'll die sooner than its average life. if u use the laptop of battery than this is not needed.
since u can't remove the battery, i'd seriously advice you to start using the laptop on battery now and then. its not a good idea to run the laptop on AC for 7 months continuously!
Any ideas?
the word "long" is subjective here. for the thread started "long" may mean 8 hours a day. for you it mebbe "7 months"!!! so its better if u give the laptop rest at least one a week for a few hours.
@chesss
yes, its true and applies to li-ion battries.
09-09-2007, 11:54 AM
#22 (permalink)
ok now how much power does a laptop in b/w 40,000 use
09-09-2007, 05:15 PM
#23 (permalink)
D i s t i n c t l y Ahead
^^ no laptop will consume the same amount of power as any other
because, they are all different some are more efficent than others
it depends what your doing some times your laptop will need to use a lot of
power and other times it wont and how you have manadged you power
settings
If u want to calculate electricity consumed by ur laptop follow this link:
http://michaelbluejay.com/electricity/measure.html
09-09-2007, 11:14 PM
#24 (permalink)
Wire muncher!
simply turn over the AC adapter and find the output wattage of it. divide it by 1000 to convert it to kW. now multiply the hours you use. u get it in kWh which is the no. of units. multiply it by the electricity rate and u get the amount. thats the max. energy that will be consumed.
for e.g my laptop has a 90w adapter. so thats 90/1000 = 0.09kW. if i use it for 8 hours days the no. of electricity units i'm consuming is 0.09kW * 8hours = 0.72kWH = 0.72 units of electricity.
09-09-2007, 11:42 PM
#25 (permalink)
Console Junkie
^ Arey yarr... Not 7 months continuously.... I give it a brake from time to time... Maybe 10-15 days. And due to power problems, I had to use it in battery many times. So, have been doing that...
--- Console Junkie
09-09-2007, 11:54 PM
#26 (permalink)
Wire muncher!
yeah, if u regularly use the battery then its fine, no worries
10-09-2007, 01:34 PM
#27 (permalink)
tHANKS FOR POSTING THIS  you made my day!
Mine shows an output of 19V * 3.42A ,
which comes to 60 watts, so running it 8 hours a day would cost only 2 rupees MAX
Now thats ridiculously cheap !
10-09-2007, 03:36 PM
#28 (permalink)
Wire muncher!
^^^ yeah, jus add some buffer to it as some energy is lost as heat also. say about 10W or so.
10-09-2007, 07:55 PM
#29 (permalink)
TheSaint
Laptop can be used if you are leaving it for some overnight work. It takes little power, even UPS will give more backup, and it has a battery of its own. Good if your downloading
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
Search this Thread |
