Originally Posted by theraven
ask ur isp to check ur cable connections
from ur side i mean .. they'll say everything is fine on their side
also ask them to check the switch u are connected to !
it could be possible that one of the ports is causing the switch to hang at times
if possible check ur net connection on another pc if u have one !
u can spoof ur mac address ! if u can check on another pc post here ill tell u how to spoof mac add. or simply google it !
Sorry I use sify broadband and i have only one pc. And u don't believe
that my connection was unplugged for over 2 weeks and when asked, they say port does not reply or it will be replaced..something like that.. or hub was damaged in rain. Now thinking to change to TATA INDICOM broadband
