i've got an intel d865gbf mobo and a p4 2.66ghz alongwith a gigabyte radeon 9600se 128 MB card. till recently i had RAM of 256MB DDR266. now i've added another 256MB DDR266 stick. the problem is that this config isnt working in dual channel mode even though the sticks are installed in channel A DIMM 0 and channel B DIMM 0, ie they are matched symmetrically.
now, i've done some googling and what i know is that for dual channel config the sticks shd have...
1. Same density
2. Same DRAM technology(128 M-bit, 256M-bit, 512M-bit)
3. Same DRAM bus width(x8 or x16)
4. Both either single or double sided
the densities are same, of course. but how do i find out the DRAM tech, DRAM bus width and whether the sticks are single or double sided??couldnt find much with google...plz help.
also note that that on both the sticks 32Mx64 is printed, and one of them has half the ICs as compared to the other.
thanx,
chaitanya
