Old 11-03-2005, 03:35 PM   #1 (permalink)
godsownman's Avatar
Default Recover Lost data
I have deleted a file from my system using shift delete
Now I want to recover that file .
I had read about a software but unfortunately i cannot find that thread.
Can anybody please tell me the name of the software or please give me the link of that thread.
I would prefer that link it has got all of it .
Please help me
godsownman is offline
Old 11-03-2005, 04:05 PM   #2 (permalink)
kl_ravi's Avatar
Recover My files is the best software for you. Check out this month's Digit DVD/CD.....
I has a friendly interface. It can recover even lost outlook mails, pictures zip archives etc.,
It is not free though....
kl_ravi is offline
Old 11-03-2005, 04:34 PM   #3 (permalink)
vysakh's Avatar
dude search before you post
here is the solution
Incompatible message format
vysakh is offline
Old 11-03-2005, 04:44 PM   #4 (permalink)
godsownman's Avatar
Hey dude I searched but the subject of the thread is not so correct so it does not aid your search.
Actually i have been searching for the past 3 days
Thanks a lot for all your effort
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
Old 11-03-2005, 05:05 PM   #5 (permalink)
vysakh's Avatar
dont care about the subject of the thread. Did you read it? indrajit deleted a file using shift+del (like u did) and asked how to recover it. (that is xactly what u asked)
enoonmai solved it for him
vysakh is offline
Old 11-03-2005, 09:07 PM   #6 (permalink)
hack expert's Avatar
hey check out the thread above also for ur information pc inspector is the best freeware available to do the task
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 14-03-2005, 02:17 PM   #7 (permalink)
godsownman's Avatar
vysakh
Yes I have read it and implemented it .
Thanks for taking the trouble .
